Question about Pool & Spa
My heater comes on but only runs for a short time then stops. It shows not problem code. The only thing that showed once was at the bottom of screen FL O & a service man above.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Go to a larger GFI breaker .for the heater element. Make sure the circulation pump is running and the pool is full of water. adjust the water temperature button to 100, the water level lever to middle, Check the ground conections for corosion, Did you servise the filter element and did the back wash regularly , check the presure at the pump gauge .Vitally
Posted on Jul 02, 2009
Heater starts then stops. Screen shows reset and fault 13
You need to look on the legend on your furnace blower door for the meaning of this error code, it can only be a few things, since you say the unit lights up and runs but shuts down the high limit circuit is suspect, I would check the air filter and insure all supply vents are open, the limit may be bad however a cracked heat exchanger will also do this so a free inspection by your gas co will be a great idea once you get it running again.
Apr 06, 2015 | Heating & Cooling
Unknown error code
if heater runs then you get that heater is overheating if not working need new display board
Jun 11, 2012 | Jandy Digital Lite2 Lj250 Btu Heater,...
Fans running non stop on T 5026
a snap usually suggests a short circuit which can be an indicator of worse things a bout to happen
go to task manager(ctrl alt del then bottom option)
check to see if cpu is running hot(middle tab at top shows performance)
could be a pre cursor of bad things on cpu in near term
May 25, 2012 | E-Machines Computers & Internet
The check engine lite won't go out after removing the power comander module. 2005 dyna wide glide
Chances are the PC created a trouble code that has not been cleared.
Use your speedo to check for codes.
1. With the bike off, push and hold in your odometer reset button.
2. with the button pressed, turn the ignition on, make sure your run/stop switch is on.
3. your speedo will do a sweep and when it comes back to 0, let your finger off. You should see a variety of letters, PSS ect. if you push the button briefly you can toggle between letters, you need to check every letter. So when the letter is blinking, press and hold the button untill the screen changes. Codes will show up as P0112 or B1110 ect. keep pushing the button untill you have all the codes. You will know when your done with the letter because it will show a part number, Example, P/N 19999-03 ect. Once you go thru every letter like this, writing down the codes, you can look them up online as follows: Harley DTC P0099 ect.
4. If no codes are present, it will go staright to the P/N. and you can click out of that to the next letter.
5.To clear the codes at this point, while you are looking for codes under the different letters, Simply press and hold the button, once it shows you the code.
So show the code, press and hold button till cleared, then press and relese button quickly to move on to the next number.
If after that, you turn the ignition off, then back on like normal, and the light should come back on shortly, but, once you start your engine the light should be off.
May 11, 2011 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
Dishwasher will not run and its showing a code of tE. Any idea what the problem might be ?
The thermistor is located between the terminals of the heater and comes as part of the heater assembly. You will need to pull out the entire dishwasher to replace it. The heater assy is stuck into the side of the sump,you can access it from the bottom of the d/w once ou have it out. The only source of parts in the US I know of is LG in Huntsville AL.
Aug 27, 2010 | LG LDF6810ST Stainless Steel Built-in...
Don't know how to set my toyostove 73 laser?
Go to this site. They have manuals and other info. for toyostoves. www.rural-energy.com
Nov 08, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Ice form in evaporator
you have defrost problem 1 timer 2 heater 3 heater remove the back panel in the freezer turn timer on till fridge go off if heater come on change timer and defrost thermostart
Apr 07, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Random blue screen of death
The blue screen of death gives you an error code accross the bottom of the screen. Something like Stop: 0x0000........
go to microsofts website and on the search bar at the site type in the code beginning with Stop.....Microsoft has causes and solutions for the codes there.
If you know the code please post it. I may be able to better assist you with the code or error message.
Hope this helps you
Oct 27, 2007 | Acer Aspire 5004WLMi Notebook
Pool & Spa Logo
244 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
