Question about Pro-Fit Pro.Fit Bm 51 97 Bmw 528i/540i/530i 97 Up
2003 bmw 530 engine fans are not going off.
I have a 2003 bmw 530. I turned it off about 30 minutes ago but it seems like the fans that cool the engine are still on. It was pretty hot outside today (about 95) but no hotter than it usually gets. Should I do something?
  • 437 Answers
Replace the temp sensor. It's stuck on on. it will kill your battery leaving the car unable to start. The fan uses an enormous amount of amps.
Posted on Jan 03, 2010
  • 118 Answers
Only worry about it if they don't go off at all? sounds normal to me but if there not going off than you have a bad relay to the fans
Posted on Sep 26, 2009
When I turn the engine off the engine cooling fan stays on and does not shut off
depending on the engine temperature the fan is supposed to remain on after you turn the engine off, until the engine reaches a preset cooler temperature. when it reaches cooler temperature usually within 5 minutes or so it should cut off... if you cut it off and it is running 30 minutes later.. then there is a problem with the fan relay or temperature sending unit.
Sep 28, 2015 | 2009 Dodge Grand Caravan
I need to find out what code po734 is on a 2003 bmw 330 ci
from a little research the code seems to indicate transmission problems. check here -
http://engine-codes.com/p0734_bmw.html
Jan 21, 2015 | Behr 2003 03 BMW 330Ci Auxiliary Fan-2003...
Dodge Caravan 2003 turns off
Hi Spepovska, Pull out the engine dip stick and observe the oil. If it has become a distinctive light grey that could indicate a blown cylinder head gasket. It seems the engine may have over heated. I think a good idea is to take the vehicle to a different shop and have them carry out another diagnostic scan and see what that one comes up with. Ask them to, carry out an integrity pressure test on the cooling system as I believe the cooling fan issue still needs attention and does not cool the engine. Let us hope the engine has not been damaged. Ask the new workshop to test the thermostat fitted to your engine and to replace if required. I believe that could be where the problem began.Regards John
Sep 08, 2012 | 2003 Dodge Caravan
2003 bmw 325i makes buzzin noise after driving for half an hour on a warm weather
If this is after you stopped the engine , is is possible the Cooling Fan is still powered for a short time to cool the system even after you left the car.
In some rare occasions ( VW vr6 p.e.) there is also an electrical water-pump to keep the cooling going after stopping the engine.
Apr 19, 2012 | BMW Cars & Trucks
My 2004 Mitsubishi Lancer Ralliart fan stays on for about 10 seconds after I turn my car off. I checked the fluids and I topped off my coolant.
hello, these cars will do that, comp goes through, a cycle, fan usually last thing to turn off, it may not do it all the time, depend on how hot it gets, plus cools engine after its turned off
Mar 31, 2010 | 2004 Mitsubishi Lancer
Hello, what does it mean when the fan is still running after the car has been turned off. it's still running after 1 hour
Most electric fan will run after car is shut off when it is hot, to cool the coolant. They shouldn't run for more that 15 min tops. It sound like a timer is malfunctioning.
hope that helps
Feb 03, 2010 | 2003 BMW 325
BMW 328i AC Not Cooling
Check the temperature control box.
Jul 30, 2009 | 2003 BMW 5 Series
Suzuki liana 2003 only done 14000 km will only run for 20 minutes
Have you checked all fuses for the cooling fans? Seems to be that the car is warming up to temp and then some, and protecting itself from overheating by shutting down the engine.
Jan 04, 2009 | 2003 Suzuki Aerio
Jetta 2003 2l fault code p2182
P2181 Cooling system performance
Check Thermostat operation & Temp sensor for ECU. CHECK ENGINE CCOLANT TEMP SENSOR IN WATERHOSE, NORMALY A 4 PIN PLUG. ON SENSOR SELF PIN 1&3 OR C&D AT 0 degrees
5000-6500 ohms,60 degrees 530-675 ohms,90 degrees
200-275 degrees
Could also be the cooling fans - I've heard of fixing it by replacing the fan motor and clearing the code as well. The easy fix seems to be the coolant sensor though - I've seen several online threads where owners cleared this code by changing that sensor.
Aug 07, 2008 | 2003 Volkswagen Jetta TDI
Pro-Fit Pro.Fit Bm 51 97 Bmw 528i/540i/530i 97 Up Logo
160 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
