Question about Panasonic Televison & Video
Convergance is crooked
My convergance is off: blue is high and right and low and left. Additionaly i have already replaced the ICs, and no change. what do i do
  • 1 more comment
  • angnjonny Jul 02, 2009
    it is like shadowing slightly off
    It is a 1999 rear projection Panasonic PT-51G54A
    Scholar:
  • 73 Answers
Depends on the brand of TV. Is the convergence off by inches or just barely? Please clarify.
Posted on Jul 02, 2009
  • Axle80
    Axle80 Jul 06, 2009
    If the convergence is off you should only get the color bleed on one side of the image. For example, White text will be red on one side, white in the middle, and green on the other side. If you are getting the same color bleed on both sides or on both the top and bottom its likely because the coolant in the CRT guns has become cloudy from age. Typically its the blue or green. TVrepairkits.com sells a kit for $50 to help replace the coolant for most RP tv's. They also include step by step instructions and its fairly easy to do. Now this is a big IF. IF the color bleed is very sharp and just looks like its out of alignment and its running on both sides, you've got more than just IC problems, The voltages may be running hot. Honestly, you'd be better off using any repair money toward buying a new TV. Fixing this ol' boy is like restoring the '92 geo prism in the back yard. I know I hate it when someone tells me that but, well, its the truth. I don't believe they even have a manual convergence option this far back, give me a couple days to see if I can track down a better option for you.
  • Axle80
    Axle80 Jul 27, 2009
    no better option ever found. scrap it, get a new lcd or plasma while the prices are low.
    Scholar:
  • 60 Answers
You guys are awesome! I picked up one of your repair kits from tvrepairkits.com and fixed my TV in less than 1 hour. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Posted on Aug 19, 2009
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
Convergence
First look for open solder connections on the convergence ICs. next bad reisistors around convergence ICs. If you find none of this then replace the convergence ics.
Mar 25, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I have a Panasonic HDTV blue convergence is off. can't align the blue left or right, but blue will go up & down. all others will align
You have bad convergence ICs at worst....Before you change them out, look at the ICs and check for bad grounds on the pins. These ICs have a STK prefix and there are two of these. Contact wwwTVRepairKits.com. Follow the instructions and It will guide you for repair! Good Luck!
Nov 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Toshiba Convergence
You have one or more bad convergence amplifiers. Best to replace both convergence output ICs as well as check low value resistors associated with them.
Oct 16, 2009 | Toshiba 42H83 42" Rear Projection...
Convergence is off, picture curves down from the top of screen.
yes the convergence ics are crooked ( big rectangular shaped mounted on heat-sink). you can order them online. check for any open resistors on the output pins.
Mar 25, 2009 | JVC PD-42WX84 42 in. HD-Ready Plasma...
51MP392H/17 Blue convergence wont move not IC chip
You could have some opened resistors low ohms that are bad go back and ck them around convergence ics.
Nov 20, 2008 | Akai PT4298HD Rear Projection Television
Hello Again
Its possible one of the resistors were weak from the other ICs. Which way does the red refuse to move as that can help you pin point which resistor you should check
Jun 02, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Convergence problems
Convergence ICs are no doubt faulty and you could have a couple of open resistors near the Convergence ICs also. You can get the ICs and or resistors at this link. http://electronix.com/
Jan 02, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence Problems
GREEN-YOU HAVE TWO STK392570 CONVERGENCE ICS' GETTING READY TO FAIL.SOME FOLKS HAVE REPLACED THEM ON THEIR OWN,OR YOU CAN GET A REPAIR TECH TO DO IT FOR AROUND 300.00$.JOE TV
Oct 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
