Question about Dryers
Drum stop turning, dryer goes on and heats - Dryers
  • j5capper Jul 03, 2009
    dryer stopped when too wet of clothes were put inside. Smells bad like burning. I took front cover off can't find belt?
  • 3 Answers
Sounds like a broken drive belt. Take off the front cover and look for a long thin belt off the drum or broken in two
Posted on Jul 02, 2009
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
My Gas Dryer has stopped heating. I've checked the breakers and reset them...if the thermal fuse is bad, will the drum still turn and dryer run but not produce heat? I thought I had read that the dryer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
My dryers works when cold but stops working after it heats up.
does everything shut off or just heat if its just heat but motor works and drum is turning than-quickest sulotion would be cleaning the vents from the dryer and out through the wall or window whereever your vent goes. the reason it turns off is because it has a limit thermostat that turns off at about 150 degrees so when the vents are clogged the hot air cant escape anywhere so it stays in dryer and overheats quickly take off the vent in the back than turn on your dryer if it doesnt turn off clean your vents
if everything stops working than you most likely have a bad motor
good luck  feel free to reply with any questions
Jun 09, 2009 | Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
The drum on my frigidaire dryer will turn when I have a small amount of clothes in the dryer, but the more clothes I put in the dryer the slower it goes until it slows to a complete stop. When I say a...
You probably need to check your dryers drum glides Reach inside and try to turn the drum. It should be VERY easy to turn. If it seems stiff it probbaly needs new glides.
Read MORE about your dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 15, 2009 | Frigidaire GLER341A Electric Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
