Question about Microwave Ovens
Replacing microwave oven door
We're trying to replace a kenmore above-oven microwave over door, part # 8169394, but we can't get the old door off. Part came with no instructions.
  • troldan Jul 02, 2009
    Model # 665-60659000. Thanks. Any help would be sooo appreciated. My husband's getting pretty frustrated trying to figure it out. :/
  • Eric Duda
    Eric Duda May 11, 2010
    There are 2 different ways these were built. please give me the model number and I can be specific on instructions. eric
  • 5,911 Answers
The door should simply come off by opening it all to way and lifting straight up at the hinges, The door will lift off the hinge pins. On some models you may have to remove the upper grill above the door (if equipped). If you still have questions, please let me know. I hope this helps you.
Posted on Jul 03, 2009
My Kenmore Microwave slowly heats but mostly the dishes vs. the food. By the time the food is warm enough, the plate or mug is practically baking. The microwave is only 4 years old, so I can&#39
Sounds like you don't have proper microwave-compatible plates or mugs. Must have lead in them, or in the paint (!?!) Try a plastic plate or even a paper plate. I can't think of anything that would make the microwave oven do that, UNLESS it's a microwave/convection oven, in which case, the convection heater must be coming on whenever you are trying to just use the microwave function.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 24, 2014 | Kenmore Microwave Ovens
Need new glass tray for Kenmore microwave bought in 1977. Model # 99371.
They made Microwaves in 1977? wow. I would try an appliance junkyard, or ebay. We have used a microwave safe plate of the right size and it worked well. Good luck!
Apr 29, 2012 | Kenmore Microwave Ovens
Kenmore microwave model 665.69682992. I am attempting to replace the door on this model. I ordered the new door but find that the hinges are installed in the new door and cannot figure how to get the new...
I am looking to replace my Kenmore model 665.61612100 combination microwave with an updated model of the same size and specifications. Any suggestions???
Sep 08, 2010 | Kenmore 62622 Microwave Oven
I am trying to change the door an my Kenmore micro-hood. Can't get the old door off to replace it.
You can find handy exploded views at the Sears Parts Site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.####
BUT once you have the part number from the Sears site, you can often get the parts cheaper here.
Aug 21, 2010 | Kenmore 62622 Microwave Oven
My microwave has a hole burned through the door.
This can start when food splatters on the inner door, then from that point the microwaves that do the cooking are attacking that splatter eventually burning a hole in the door. Do not use the microwave oven in this condition. You will need to have the door parts that are damaged replaced
May 08, 2010 | Westpoint TV-201 Microwave Oven
Kenmore above the range microwave doesn't heat and sometimes the fan doesn't come on. Is it worth fixing or should I buy a new appliance. It's about 7 years old.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
sytjhf
Nov 12, 2009 | Kenmore 63672 Convection/Microwave Oven
How do u install a kenmore microwave oven over the
Installation instructions should have come with it. If not, do a Google search online to find the installation manual. Generally there is a plate that installs on the wall and the microwave hooks into it and fastens to the cabinet above. Try this website for a manual. http://www.pdfoo.com/result-kenmore-microwave-installation.html
Oct 30, 2009 | Microwave Ovens
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
We need to change the door on our microwave. We have the new door, but can't find anything in the manual about removing the old door. It is a Frigidaire Gallery series above range microwave. Any...
The door should come off fairly easily. All you have to do on MOST microwave ovens is open the door all the way and lift straight up at the hinges. The door will come off the hinge pins.
On some models, there may be a small hinge pin on the top hinge that you remove, then lift up.
You may have to remove the grill panel above the door (if equipped) to allow for clearance for the door to come off.
If you have questions, please let me know. I hope you find this helpful.
Sep 05, 2009 | Kenmore 62622 Microwave Oven
Part 8169394 oven door replacement came with NO instructions
If you can get to the top screws without pulling the unit down then you can do the job. Sometimes though it goes back together and alignment is simpler if it is on a table and the cabinet is off. I have successfully done it both ways but neither is what I consider easy.
eric
Jul 16, 2009 | Microwave Ovens
Microwave Ovens Logo
99 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
