Question about Canon Office Equipment & Supplies
When start my iRC3200, the touchscreen display no present any change and stay the loading sistem...please wait. image massage, but the copier make the ATR control completly. no code, no change in massage pad, nothing. another user tell me...you need reload the system software of the hard disc or reload the firmware, i don´t know how it makes.
  • Ronnie Gregorio May 11, 2010
    Try this :Shutdown the machine by unplugging from the main AC supply.Pull out the drum units and reinsert and re start if problem persist you need to call your service provider ,for this could be the problem of boot rom and HDD.this can't be done by end user
    try to switch off the machine completely by unplugging the machine from the ac supply pull out the drum unit and reinsert it restart the machine if problem persist you need to ask your service provider to check the boot rom and the hardisk of machine this cannot be done by the end user
    Sniper:
  • 118 Answers
Posted on Jul 04, 2009
How to solve error c2551 in Konica bizhub c220
C 2557,C 2558 Black TCR sensor.
C 2551,C2552,C 2559 Cyan TCR sensor.Check de consumabile life,if you have possibility change the Black and Cyan Imaging unit.Enter in the service mode Press Utility key - Metercount- Details- Stop 00 Stop 01 select Sistem 1 or Sistem 2and read the messages.For reset turn OFF the copier,press and hold the Utility key turn ON the copier and then the display appaire Trouble reset release the Utility key and touch the reset,turn OFF the copier wait 2 minutes and turn ON.
Feb 07, 2013 | Konica Minolta bizhub C250 All-In-One...
Canon ir c3200error codes
There are many error codes which the iRC3200 has, please be more specific.
i.e. copy the exact error code displayed.
Sep 23, 2010 | Canon imageRUNNER C3200 Copier
SErvice Manual IRC 2620 please
A irc3200 Service Manual will give you mostly the same info - there are very minor differences. You can get one here
Jun 24, 2009 | Canon ImageRunner C-2620 Copier
Eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
Jun 01, 2009 | Canon imageRUNNER 400S Copier
IRC3200 - Color Printing Distorted
hi
check your counter if already reach 2k
its means you need to replace the itb belt or assy
any question just leave a message
May 21, 2009 | Canon imageRUNNER C3200 Copier
CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Sep 11, 2008 | Canon imageRUNNER 400S Copier
CANON IRC3200 NOT COMING OUT OF WAIT
when stop printing you should have posted the problem then, you probable damage the board, you need to replace the booth rom first
Jul 01, 2008 | Canon imageRUNNER C3200 Copier
Printer canon
there is the heater bord problem in your printer
Sep 15, 2007 | Canon imageRUNNER 400S Copier
146 people viewed this question
old marine
old marine
