Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Briggs & Stratton engine just dies
Does this machine die when overheated? It seems when I have to cut grass that is really long..it's ok till I go up a hill and then it coughs and dies. After about 20 mins it will start.
  • 218 Answers
Hi..my name is Keith..and to answer your question..lawn mower engines are air cooled and are well engineered and they dont overheat..and i dont know of the steepness of the hill you are going up..but it sounds like the engine is either running out of fuel on the incline or the oil in your crankcase is running to the rear of the engine and the low quanity sensor is shutting it down..i hope this will help..if not please write me back
Posted on Jul 08, 2009
Hello i am working on tryin to fix the problem yall are haveing an my theiry is that the carb neee is sticking after the exhaust gets hot.it seem like maybe a valve adjustment an replaceing the needle should fix the problem on the 26hp
Posted on Sep 13, 2012
SCAG FREEDOM Z 26 HP BRIGGS EXTENDED LIFE.SHUT DOWN IT IS GETTING FIRE BUT NO FUEL .I GET FUEL FROM THE DISCHARGE SIDE OF FUEL PUMP.WHAT GIVES
Posted on Oct 30, 2009
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
I have several series 50 briggs and stratton lawnmowers after running for a while they overheat and cut out, what causes this &show can I fix this.?
Take off the recoil starter housing and clean the mouse nests out from under it. You might also find grass packed in there.
Aug 07, 2014 | Briggs & Stratton Garden
Engine is misfiring.
Put the old plugs back in. The new plugs my not be gapped correctly or one may be bad.
May 05, 2014 | Briggs AND Stratton Intek Briggs &...
My briggs and stratton twin cylinder engine runs good until I try to mow with it. The engine dies down and will cut off unless I disengage the mower.
If you are cutting to much grass this can happen or if the throttle control is not in fast speed (rabbit). If it is in slow speed (turtle) it will tend to die down in tall grass or wet grass. Good Luck...
Aug 16, 2011 | Garden
I have a white mower with a 18 hp intek v-twin briggs & stratton motor. I was cutting the lawn and it loss power all of the sudden, then it died. Now it won't start. I changed the plugs, which looked...
back pressure is from a blocked muffler ( carbon build up)
if it is that old then it could be overheating from grass and dirt build up around the cylinder fins and not cooling properly
Apr 06, 2017 | Briggs & Stratton Briggs Stratton Intek V...
17.5 briggs on craftsmen riding mower
i gess you busted the crack shaft push rod so the piston is not now moving up and down the bore
take off the cylinder head and turn the motor by hand till its at the top of the bore, then rock the flywheel to and frow if its turns a long way before the piston moves down the bore strip the engine down so you can repair it,,,if thats pos!
May 28, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Engine seems to flood out when increasing speed and dies
If it starts lightly smoking black smoke at high RPM it is flooding or getting too much fuel. The float is leaking you may have not set the float height correctly when you put that carb back together. Or the needle and set could be bad.
Sep 11, 2009 | Briggs & Stratton Garden
15.5 ohv briggs and stratton
It could be "starving" for gas, not getting enough gas. Check the plug, if it is white then the engine is running to lean and will overheat. If this is the problem, then the carbertor will have to be adjusted, and or cleaned, or replaced.
Jun 23, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
655 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
