Question about Yamaha MX-D1 2-Channel Amplifier
Yamaha RX-797 iPod Integration
I'm working with Bose 901's with an equalizer and a Yamaha RX-797 receiver. I can get a tape deck to work with the equalizer, but have not yet been able to get my iPod or Macbook to connect with the equalizer. What is the best way to go about connecting one of these two audio players?
Thanks,
Bryan
    Brigadier General:
  • 8,546 Answers
I have a question first... are the 901's amplified by a separate amp as they should be in a multi-channel (non-stereo) setup?
Better yet read the following then decide if you have iy set up right to begin with. If so, I'd just treat the Ipod or Mac as auxilliary inputs on the receiver. :
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
Posted on Dec 28, 2009
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
I have a yamaha 797 receiver and bose 901 VI to run my ps3 to my receiver it has no hdmi or optic
The manual for the 901's is here.
http://www.bose.com/controller?url=/shop_online/speakers/stereo_speakers/901_speakers/index.jsp
For the purpose of this discussion the 901 active equalizer is the same as any Tape deck or audio processor. You could place the 901 Active Equalizer in the VCR or MD/Tape loops; or remove the Pre Out / Main In jumpers and place it there but that would you could never use headphones as they wouldn't sound right with 901 active equalization. See page 10 and 11.
The PS3 is just in audio device for this topic. Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 28, 2011 | Bose 901 VI Main / Stereo Speaker
I am using the "
http://www.retrevo.com/support/Yamaha-RX-797-Receivers-manual/id/320ag612/t/2/
I assume you've placed the Bose Active EQ in where the Pre-Out >> Main In jumpers were. Do you have the return from the Bose Active EQ going back into the Main In so it can continue to the Sub Output.
Or do you have the Bose EQ Tape Switch activated incorrectly?
Feb 03, 2011 | Yamaha RX-797 Receiver
I have a Yamaha RX-V992 receiver and I would like to install a Bose 901 active equalizer Where will I connect this to my receiver? Thanks Mark
Basically here are the connections you have to do:
In case you don't have tape recorder forget the "box" named tape recorder. Your RX-V992 is the box named receiver or preamplifier. You have to connect with RCA - RCA cables the tape out from the RV-X992 to Bose input, and the Bose output to tape in at RV-X992. With the setup connected like this whenever you choose from the RV-X "tape monitor" you will hear the sound equalized from Bose; if you disable the "tape monitor" switch you will hear without any equalization.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 09, 2010 | Audio Players & Recorders
Want to use Yamaha rx-797 reciever with bose 901 and bose 301. Yamaha says tape monitor kills digital input signals. Also sya digital inputs are the optical jacks, RCA inputs are analog, but 797 does not...
I don't know why the comment from Yamaha about Tape Monitor killing digital inputs is relevant.
According to the manal I downloaded, THIS stereo receiver doesn't have digital inputs.
As to using 901's and 301's...
You will need a separate Power Amp for either the 901's or the 301's. Sorry, but you can't share the amp with the Active-Equalized signal and non-901's.
I use 901's and 301's in MY 7.1 rig with a separate amp for the 901 and NOT using a Tape Monitor, but a preamp out feed for the front channels.
Feb 15, 2010 | Yamaha RX-797 Receiver
I want to use my 901 speakers with the yamaha rx 797 receiver and also my bose 601 in same room can i do that?
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver2_bing.gif will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers2_bing.gif and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers2_bing.gif.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier2_bing.gif that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
Jan 05, 2010 | Yamaha RX-797 Receiver
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer
Hi Mark, had a look for a manual on your Yamaha, but not got to one as yet. Does it have any RCA connections on the back marked as preout prein? best place to put the 901 EQ is in line with L and R front channels at this preout prein point.
Some amps DO NOT HAVE IT. If our does not, then you could connect it in the tape loop, tape out(rec) to input on the EQ. and the output of the EQ connected to tape in(play), but connected like this, the EQ would affect the tone across all channels(unless you are just running a stereo rig, then this way works great!!) Try this and you may just have solved you problem anyway.
regards
Graeme
Mar 28, 2008 | Audio Players & Recorders
Connecting Bose 901 Series VI Direct Reflecting Speakers to JVC RX-8020VBK Receiver
in order to make those speakers sound good (if they can sound good at all) you need to use equalizer box witch came with them. If your receiver does not have tape monitor loop or preamp to amp jumpers you can not use those speakers. To be honest you do not loose much... none of this stuff is any good (sorry for bad news), but if you like those speakers (I know they have big fans, even if in HI-FI world, they not consider as good) you have to change you receiver. Dariusz
Feb 13, 2008 | Bose 901 VI Main / Stereo Speaker
Yamaha MX-D1 2-Channel Amplifier Logo
512 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
