Question about Pentax Optio MX4 Digital Camera
How do I delete the photos from my SD card?
How do I delete the photos from my SD card on my pentax optio mx4?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Format the memory on internal and disc.
Vitally
Posted on Jul 02, 2009
Digital camera.Can images be recovered from S D card on Pentax Optio W10
yes but first be sure you have the correct sd card for Pentax optio find info by looking up the items here,
www.procellularservices.com, even if you pull up an item and scroll down and see were it says frequently bought together, those are mostly likely items that match your device...
May 13, 2018 | Pentax Cameras
Recover deleted photos
Yes, there is a way to retrieve photos from your Pentax camera.
Chances of recovery can be high as long as you act as soon as possible and stop using the digital camera to take more photos or videos, also keep the camera memory card in good shape (no physical damage).
Then you can rely on a digital camera data recovery software to get the job done and retrieve your photos. Here shows a list of good ones (for PC/Mac) http://www.digital-camera-recovery.com/
You'll need to connect the camera (mass memory card) to your computer. Then install the program to start scan & recover your files. Should be easy to get back your lost memories!
Feb 12, 2012 | Pentax Optio MX4 Digital Camera
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
What is the "card locked" ? when the camera comes
Your memory card is an SD type. These cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Nov 04, 2010 | Pentax Optio MX4 Digital Camera
Does an 8gb sandisk fit in this camera
I have succesfully used 2 GB. I believ that is not the size, but the type of card that may not work. SD will work without problems, but SDHC will not.
Oct 21, 2010 | Pentax Optio MX4 Digital Camera
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
Feb 22, 2010 | Pentax Optio S5z Digital Camera
Pentax Optio MX4 won't read my new SDHC 4gb
Does the camera work with any other card? Was the card formatted in the camera? Some cards from some manufacturers just don't work in some cameras.
Sep 12, 2009 | Pentax Optio MX4 Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Pentax optio mx4
gently tap on the silver ring on lense, while turning on and off the camera, it fixed mine after reading of this fix here on this site
Aug 30, 2008 | Pentax Optio MX4 Digital Camera
Can't take image with my optio mx4
I had this on mine, and after searching on the internet concluded it was a problem with the lens assembly. Taking the view that I could not lose, I disassembled the camera, which is probably not advisable. The problem I think was fixed, by gently tapping the front of the camera on the silver lens surround with the handle of the knife I used to undo the screws. I did this on repeated switch on, and after a fair number of times, the lens moved and the camera came back to life.... Re assembly was a bit tedious, but I was left with no screws or extra parts!!. One working camera and one happy son who has been using it for skate board video ing.
Mar 27, 2007 | Pentax Optio MX4 Digital Camera
Pentax Optio MX4 Digital Camera Logo
101 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
