Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Push to talk problem
When i push to talk on radio #1 there is no sound coming from radio #2 as if i have a mic problem on radio 1 . From radio #2 to #1 everything is fine. How do i repair a mic problem
    Brigadier General:
  • 6,966 Answers
Re: Push to talk problem
If indeed radio #1 has a mic problem, this may be confirmed by trying an external speaker/microphone plugged into the accessory jack. If still a no, then its not the mic but possibly the modulator circuitry. If there is transmit audio with the external mic and hence internal mic is defective, the unit would have to be pried open and the defective component replaced. The internal mic is normally an electrofet 2-3 terminal soldered to a shielded wire and physically attached to the front plate.
Alternately, another possibility is that radio #2 has its Interference Eliminator Code enabled/activated. This is indicated by the presence of small sized digits on the top right of display. If this is the case and no similar digits are displayed in radio #1, then radio #2 will not allow any received transmission to be heard. Along the same line of reasoning, if the code is activated on both radios signified by the presence of the 2 small digits, and radio #1 has a problem with its CTCSS (code) generator, then it would also prevent reception of radio #2. A way to verify this is by deactivating/disabling the Interference Eliminator Codes on both radios.
On certain occasion, it is also possible that radio #2 has a defective speaker. You should be able to verify this by plugging in an external speaker to the accessory jack of radio #2.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 10, 2007
0 characters
3 Points
Ft 2900r when I push then talk button on mic it shows error on all channels even with second mic
Sounds like a programming error. Does it work properly in VFO mode? Did you try a reset?
Jan 10, 2015 | Yaesu Ft 2900r Vhf Mobile 75 W Two Way...
Radio beeps after you release push to talk
Might be a low battery warning. Try swapping battery.
Mar 20, 2014 | Motorola CLS 1410 (4 Channels) 2-Way Radio
When i push the mic the screen scrambles
Change the Mic, check the Power Supply, check the antenna connection because your TX side have a problem.
Jan 09, 2014 | Motorola Two-Way Radios
It has a PTT (push-to-talk) button. But if you are talking about a button to make a call tone (ringing sound) come out the other radios, the answer is no.
Best regards.
Apr 10, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Only one walkie talkie produces sound
Check for Squelch Codes you can see on the display channel number and sub chanel number this is the squelch code
Both displays must show the same icons
If both are the same, try with and audio accesorie, if works may be your speaker is broken.
Dec 23, 2008 | Bell BE1400FRS (14 Channels) 2-Way Radio
T 5710 motorola talk about
Short of having a radio tech look at the radio, I would suggest looking at the grill and mic hole to see if there is dirt or debris blocking the hole.
Oct 26, 2008 | Motorola Talkabout T5720 (7 Channels)...
If i want to talk to my passenger what do i do?
you will need the headset extension cord. push and hold the "int" button till a beep is heard then either ptt or vox
May 14, 2008 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
230 people viewed this question
Top Motorola Two-Way Radios Experts
bill tarkulich
Level 1 Expert
Are you a Motorola Two-Way Radio Expert? Answer questions, earn points and help others
