Question about Nokia 6085 Cellular Phone
My phone says there is a wired enhancement attached, but there isn't and now it doesn't ring.
My nokia n 73 phone is howing enhancement symbol on the right corner of the screen even if no enhancement is connected and when i make or receive calls, i am not able to hear the other persons voice and...
try to clean the headset interface at the bottom,might the socket is corruded and lead inoto shortage...
if that symbol never removes.you can never hear incoming calls or even the person calling might not here you...
if doesn't work,bring it to a mobile srvice shop near you. might a hardware (board) problem.
hope it helps....
Jun 04, 2011 | Nokia N73 Cellular Phone
My nokia radio off
If you turn on your radio and it does not come on as you say, there are different sides to the problem.
1. If when you turn it on, it does not come on, and probably tells you that 'enhancement is not supported', then the problem is from the enhancement (ear piece). Get another enhancement and try again. If you have done that and it still was not helpful, or the problem was not even from the enhancement, then proceed.
2. If when you turn it on, it shows a station or frequency number on the screen, but you dont hear anything, then the ear phone of your enhancement is faulty. To confirm that the problem is from the ear phone, select
options> loudspeaker.
If you hear the sound, it confirms that the ear phone is bad.
You can then use your old enhancement on loudspeaker or get another enhancement.
Hope that helped?
Success.
May 10, 2011 | Nokia Classic 2700 Cell Phone
My nokia 5200 radio does not work
Your enhancement may not inserted properly, enhancement used as antenna. so insert the enhancement(eg: headphone) properly. if you done the same but then aslo there is same problem Then do restore factory setting, else go for Software update, your phone os may crupted.
Apr 09, 2011 | Nokia 5200 Cellular Phone
My t mobile tap phone can make calls and receive calls but it doesn't ring because the headset icon is on and I can't disactivate it.
just go to sound profile then change it to normal .
if it doesn,t work
go to enhancement and change to normal
it will work .
Dec 29, 2010 | Cell Phones
My phone displays "enhancement not
when its display this message? if its display when you try to attach handsfree with your 6233 then try another handsfree which support your cell phone model,you can found which type of enahancement support your phone at nokia website
Nov 01, 2010 | Nokia 6233 Cellular Phone
Enhancement in use
You ca reset your phone settings to default, this will clear your own settings, which will probably fix the problem. please note that if your phone has a Pin code or a password you set, you will be required to enter the password or pin code to reset your phone
resetting will not delete your contacts and messages.
Jan 07, 2009 | Nokia 6670 Cellular Phone
Phone enhancement
try reflashin the phone thaht may help
Jun 13, 2008 | Nokia 6233 Cellular Phone
Radio problem
Did you connect the wired headset before you activated the radio?
May 04, 2008 | Nokia 6233 Cellular Phone
Shows headphones on when they not connected so cannot hear calls or ring and hear people unless headphones are plugged in need help please
buddy
try out one thing reset your phone once by using this code, *#7780#,it will ask your password, put it will delete all your phone stuff the contact and the messages before doing this transferr all your matter to memo card.
it will help you.Best Of Luck.
Thanx
Do vote if this solution works for you.
Jan 04, 2008 | Nokia N70 Cellular Phone
N70 headphones
Go to.
Menu/Tools/Settings/Enhancement/Enhancement in use/
Change setting to Headset.
Nokia 6085 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
