Printer will not quit feeding paper and does not print the requested page, just prints a line or two of weird symbols per page over and over.
    Problem Solver:
  • 6 Answers
Your driver on your computer is bad, power off the printer, (your printer will not stop printing the gibberish). Download the driver through your control panel. Once you go through the steps to set up the new driver, it'll print out a test print. *It'll ask you if you want the new driver as your default printer, say yes. I would delete the bad driver after you set up the new driver.
Posted on Jul 02, 2009
The printer feeds to much papper
The first thing you need to do is to check the paper size selected in the application you are printing. If you are printing from a Windows based application you WILL find that the paper size selected in the application you are printing from is set to A4.
On the printer you can set the paper size in the following way;
  1. Power the printer ON holding down the SETUP button to unlock the menu, release SETUP when the printer finishes initializing
  2. Put the printer OFFLINE press SETUP
  3. Press the button under MENU
  4. Press the button under NEXT until you see FORMLEN (if you do not see FORMLEN select the PAPER option it may be a sub menu for PAPER)
  5. Press the button under TRACTOR 1
  6. Press the button under LINES
  7. Use button 2 to reduce the number of lined to 18 (3 inch x 6 lines per inch)
  8. Press the button under SET to save the setting
I am assuming the form length is 3 inches, if it is 1.25 inches this may be outside the specification for the printer and you may not be able to select this it is also not dividable by 6 lines per inch
Oct 25, 2012 | Tally T2240/24 Matrix Printer
Printed copy will not feed out line by line and finally will not feed the printed page. How to get it to work properly?
There could be something blocking the paper path that's not allowing the paper to not go all the way through the feeder. Try to open the printer and access the cartridge area. Remove the cartridges. Check for any foreign objects blocking the paper path. Rebrick your printer by removing the power adapter (black box found on the back of your printer where the power cord is plugged in) and then re-plug after 30 seconds. When your printer turns back on, re-insert your cartridges. Then try print your document again to verify that the problem is fixed.
Nov 10, 2011 | Lexmark X73 All-In-One InkJet Printer
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Whenever I turn the printer on it just keeps printing little weird symbols like one or two lines per page and then goes to the next page and does the same thing just different symbols and it goes on and on...
There is a job in the print queue. At the start of a print job a code is sent saying print the following data as graphics because you have turned the printer off it thinks that all the data is text. You need to delete the job in the print queue. Select the printer in Control Panel>Printers and it should show you a list of print jobs. Delete them
Oct 11, 2009 | Epson Stylus Color 740 InkJet Printer
Paper not feeding right
Hey. I too am having that problem with my ip1800 canon printer. It makes a weird "clicking" sound whenever I turn it on, and then when I try to feed it paper, the sheets either get stuck and become crooked and cumpled. OR, when it does sound like its printing, it doesn't print on the page--maybe the tip of the page, but not the whole page.
May 02, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
Brother MFC 8500
Hi, Make sure the rear cover is closed. 2. Usually when you get misc symbols on the printed page the machine couldn't recognize the print job. I would try printing something from another file and see if the problem occurs.
Dec 01, 2007 | Brother MFC 8500 All-In-One Laser Printer
153 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
