Question about Whirlpool Dryers
My leq8000 model dryer is not heating up. Any suggestions, it was purchased 4 years ago
rpbuice
  • 161 Answers
SOURCE: WHIRLPOOL GAS DRYER MODEL LGQ9030PQ1 DRYER RUNS BUT NO HEAT
First, as a retired Fire Captain I must recommend turning off all running appliance before leaving the house or going to bed. I can tell you some real horror stories. Now, there are several parts that can keep the heat off or flame off and they all need to be checked with an OHM meter. It could be the ignitor, ingitor sensor, or gas solenoids. Get a service tech out to check which you need or if you have an OHM meter I can give more info on what to check.
Posted on Jan 23, 2009
  • 45 Answers
SOURCE: Dryer not heating up - Amana Model # ALG643RBW
Heating element
Posted on Apr 28, 2010
heatman101
  • 43501 Answers
SOURCE: My dryer is not heating when it tumbles, I have
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 08, 2010
jsrock516
  • 5911 Answers
SOURCE: My Kenmore 700 series dryer
If your ELECTRIC dryer is still running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
IMPORTANT: Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Begin by verifying the source voltage at the receptacle and service breaker, and verify your power cord.
The reason a dryer may still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
NOTE: If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed also have helpful exploded view parts illustrations that you can use to locate and properly identify any parts you may need. If you have questions, require additional assistance, please post back with a MODEL NUMBER and let me know. I hope this helps you.
NOTE: If this is a GAS dryer, the most common cause of heat related problems is a weak or failed igniter on the burner assembly.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Posted on Apr 25, 2011
  • 251 Answers
SOURCE: My Whirlpool clothes dryer model
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Posted on Jun 07, 2011
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Why won't the dryer heat
the heater element and/or the stats may need replacing
cheap on ebay.........
cheers
Jul 28, 2017 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
My dryer is not heating when it tumbles, I have missed placed my manuel. Where can I find a replacement? Model LDG 7304 AAE purchased about 14 years ago. thank you, Patti
heatman101
May 31, 2010 | Dryers
No heat when timer is in Electronic Sensor selections.
The electronic sensor needs to be replaced.
Sep 16, 2009 | Dryers
Older Ge Hotpoint Dryer will tumble but not light the gas to heat
You state it is an older dryer, so I'd suggest replacement. The water may have damaged numerous components, including the motor, which would be costly to replace.
Aug 28, 2009 | Hotpoint NWSR483GBWW Gas Dryer
I purchased an Amana drier a few years ago and my aunt purchased the exact drier the model #ALE331RAW It heats so hot you can not hardly touch the cloths
too hot??? thas gerenally a sign of insuffecient venting, check for arestricted and/or blocked vent. it cant release the proper amount of heat and its buildingup inhte machine
Mar 07, 2009 | Amana DLE330RAW Electric Dryer
We purchased this microwave 4 months ago and the food is not heating up and do not know what model it is but it has a dial setting and is a stainless steel model.
Since it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer or dealer to get it fixed free.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 29, 2008 | Microwave Ovens
Dryers Logo
77 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
