Question about Toshiba Satellite A135-S4427 Notebook
I need the hardrive drivers mk1637gsx 160 HD SATA
I have a toshiba Satellite a135 s4527 trying to ad a new harddrive using fact toshiba restoral disks Will start to boot says loading then it says ERROR: 01-0134-0000. The tool could not get HDD physical information. Please Press [OK] to turn off the computer What can i do to get this to work
if i need the hardrive drivers where can i find these Thank you inadvance
  • 144 Answers
Theres no such thing as Hard Drive Drivers
Restore disks are created to only work with the default hard drive that came with the laptop. Even if you bought an exact replacement it still wouldnt work as the restore discs looks for the unique serial number of the hard drive and therefore prevents people from using the recovery discs on other toshiba systems or non toshiba systems.
Id suggest borrowing another windows installation disc and using the key on the certificate of authencity on the bottom f the laptop to activate.You might have to ring microsoft to activate it but just explain whats happened and it should all go ok.
If you found this helpful , please rate my solution below
Kind Regards
1234s282
Posted on Jul 03, 2009
ı want to download a wireless driver for satellite A135-S4527
Hi
Thanks for using FixYa. You can download the drivers foryour Toshiba Satellite A135-S2276 PC Notebook from the following websites---
ToshibaSatellite A135-S4527 Drivers
ToshibaSatellite A135-S4527 Drivers download
Please do rate the solution and revert for furtherassistance.
Thanks
Rylee
Oct 28, 2009 | Toshiba Satellite A135-S2276 Notebook
The HD I put in my Toshiba Satellite A135 did not come with a CD. I'm using the Revcovery CD that came with the computer. It partitions the HD then starts copying files. After inserting the 2nd CD, I get...
I have come across a similar problem when restoring a Dell laptop with Windows Vista. There is an option on the recovery disk to install drivers. Some computers that have SATA harddrives need the driver loaded before you can load the O/S back onto the computer.
Once I did this, it sailed right thru installation.
Oct 21, 2009 | Computers & Internet
Toshiba Qosmio laptop with Phoenix securecore util,uses SATA drive. Had to replace the Hard drive, HDD1 password issue After installing the new HD and at boot up, blue screen occurs I get errors F78da640,...
You've probably got to have your computer configured to boot from a rescue CD before it can recognize and install the new harddrive. Also make sure that there is an operating system installed on the hard drive . If not it will not do anything until you install one. This will be automatic if you install a new XP or Vista DVD into the computer's DVD drive the reboot.
Sep 07, 2009 | Toshiba Satellite A135-S4527 Notebook
No pass word works to enter Toshiba satellite notebook A135-S4527
I had the same problem, I used my Windows Password reset disk and still nothing. I replaced the Harddrive. Once I did that I tried to reformat my system only to get the error message that the neew harddrive was bad. I ended up taking out the CMOS battery (Over night) Next day I was able to reformat system. Note (never could get by the password. But that didn't matter because I installed Windows Xp
Jul 09, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135 S4527 PC windows xp service pack 3 drivers
Try uninstalling sp3 from add or remove programmes in control panel..because some of the drivers are not compatible with sp3
Jun 17, 2009 | Toshiba Satellite A135-S4527 Notebook
Am looking for Toshiba laptop LAN drivers for model A135-S4527 for O/S Windows XP
Try following links.You will get the driver you needed.
http://www.laptops-drivers.com/toshiba-drivers/request-download-driver-for-toshiba-satellite-a135-s4527.html
http://forum.notebookreview.com/showthread.php?t=129243
Thanks
Feb 18, 2009 | Toshiba Satellite A135-S4527 Notebook
Hard drive
You need to use a Windows install disk, or the computer recovery disk.
At startup of new windows installation, chose new installation and then chose the option Format hard drive.
Note: the windows install disk must be bootable, Upgrade install disk (non bootable) does not have the format option.
Regards
Nov 05, 2008 | Toshiba Satellite A135-S4527 Notebook
Wont shutdown or hybernate on ac adapter, ok on battery
You might need to do a system restore from an earlier time from tools menue in accessories/or use a recovery cd/or format your HD
Aug 14, 2008 | Toshiba Satellite A135-S4527 Notebook
All drives xp for Toshiba Satellite A135-S4527
Ok just to clear the question up... I you just installed a new HD in your laptop and have already downloaded your recovery cd that came with the pc then you are asking for the remaining drivers that you are missing... if so here is what you need to do. If you are not missing your internet driver go to www.driveragent.com this requires a yearly membership of I think 29$ This will scan your pc and give you the drivers to download. If you just installed a new HD and if you turn your computer on and get nothing this is because you did not install your recovery disk,,, if you do not have your recovery disk ONLY Toshiba can provide this and you can order it from them. I would also call Toshiba for your driver disk as well if you cannot get on the internet...
Jun 12, 2008 | Toshiba Satellite A135-S4527 Notebook
Drivers for Toshiba Satellite A135-S4527
type this in your search engine ....
toshiba support-content list
some tittles of exactly what you typed in will display...
click on one and youll be at the download page...
just been there.I'd type the page in for u but its very long as youll see when u get there.
Apr 12, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4427 Notebook Logo
155 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
