Question about Dishwashers
KitchenAid KUDR24SE dishwasher doesn't drain.
I have a KitchenAid KUDR24SE dishwasher that isn't draining properly. About an inch and a half of water remains in the bottom of the cabinet at the completion of the cycle. I checked the troubleshooting section of the manual and ensured that the cycle had finished. There's no air gap installed. The Overflow protection float moves normally.
What should I do next, short of calling the repair person?
Thanks.
  • clkpoet Jul 04, 2009
    Thanks, haundi24. I'll check that if this happens again.
    For now, the problem was solved by running the dishwasher on its Regular cycle. We'd been running it on Light China when the problem occurred. For some reason, the Regular Cycle drained the compartment.
I had same thing. I disconnected the line at the checkvalve and water drained fine. (and a lot of water, dish out the basin first!) Then I blew hard on the line going out to the disposal and finally heard things clear. ALSO I reset the circuitboard. Instructins here:
http://www.flickr.com/photos/zenzoidman/389141915/in/set-1155952/
Posted on Jul 15, 2009
  • 90 Answers
Check the drain tube at the disposer
Posted on Jul 02, 2009
Testimonial: "Thanks for the heads up."
  • clayton winklepleck Oct 17, 2009
    check drain line under sink it should loop up above sink drain this keeps greese from building up in hose thahks for your coments haundi24
Water does not empty from dishwasher
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | Maytag MDB9750AWS Built-in Dishwasher
My diswasher does not drain.
Hi
Thanks
Rylee
Jun 08, 2010 | Whirlpool DU960PW Dishwasher
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
Dishwasher will not drain
Hi
Thanks
Rylee
Dec 11, 2009 | Dishwashers
What do I do if the water won't drain out of my Kitchenaid dishwasher?
Hi
Thanks
Rylee
Dec 08, 2009 | KitchenAid Dishwashers
GE GSD4920Z dishwasher. Problem is that it does not drain completely at the end of the cycle--about an inch of water remains. After checking for clogs, etc, we followed a troubleshooting procedure which...
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | GE 24 in. GSD4920Z Built-in Dishwasher
The water is not draining. no clog in the drain house or plumbing
Hi
Thanks
Rylee
Nov 09, 2009 | KitchenAid KUDC25CH Dishwasher
Water not draining from diswasher
Hi
Thanks
Rylee
Nov 03, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
Dishwasher won't drain
Hi
Thanks
Rylee
Oct 22, 2009 | KitchenAid Dishwashers
Dishwashers Logo
358 people viewed this question
Top Dishwashers Experts
