I believe SE means shorted keyboard. You would have to replace the keyboard, which is usually part of the control console.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: Whirlpool Microwave Model MH3184XP
This is most often caused by a bad magnetron "scrambling" the controller, a bad connection on the controller, or a controller failure. Try to use the "timer" function of the oven. Make it count down without cooking for about a minute. If it works, then it's more likely to be a bad magnetron. If it still fails, it's probably a problem on the controller. We repair these nationwide by mail for $39.95 in most cases. For more information see our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: My Maytag microwave has error code "SE" on the
SE error means you
have a shorted membrane keypad.
The full model number would be MMV1153AAB or MMV1153AAW and denotes color.
On this model, the membrane keypad is not available as a separate part,
so you would have to order the control panel frame assembly ("control panel/switch" as it's called) which comes
with a new keypad.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Some connectors have a lock:
Then carefully (since the display is made of glass) move your
circuit board to the new frame, and reassembly is the reverse of
disassembly.
You can get the part from the Pros here. They're our favorite supplier.
You can also find helpful exploded view diagrams at that link.
We're happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
Hello Arold - Typically, error code SE indicates a shorted keypad. Try resetting the microwave by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the touch keypad on the unit will need replacing.
