Question about RCA WHR50 Consumer Headphones
Need RCA part
Where can i get replacement ear pads for thr RCA WH150 model headphone?
SOURCE: ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
Posted on Nov 14, 2008
  • 20 Answers
SOURCE: I need a replacement rubber ear pad for one of my headphones.
most best buy stores have extra axcessories where the headphones and portable tape players are. try there, they might have them.
Posted on Mar 19, 2009
SOURCE: how much does it cost to replace pads for my headphones
I just removed mine, soaked them in rubbing alcohol and now they are sterile and ready to use again. Oh, I forgot to mention they are now devoid of that sweat-like animal odor and garden soil - I am an avid gardener and long distance runner living in a hot, humid climate. You can also replace any damaged or worn out foam with similar products found in old cushions etc.
Hope this helps.
Posted on Jun 16, 2009
SOURCE: I need new ear pads for my Aiwa HP-CN5 headphones.
I hunted around. No luck. Then I stopped in an found the perfect fit from of all places Radio Shack. The Earpads come with a smaller pair and you have to buy both but they are an excellent replacement. The Radio Shack replacements are #330-0288 - Replacement Headphone Earpads - $6.99 USD.
Posted on Jul 17, 2010
  • 4518 Answers
SOURCE: replacement foam ear pads for headphones
Try this site: JNTWorld. I highly recommend it.
Posted on Aug 11, 2010
  • 4518 Answers
SOURCE: the headphones work perfectly but the ear pads are
Try this site:
Posted on Nov 09, 2010
0 characters
1 Points
Replacement foam ear pads
Yes you can. Go to my blog site and you will see a link to a place that sells them.
Apr 12, 2014 | Philips SBC HP400 Headphones CS01 Stereo...
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
Sony parts suppliers sell replacement ear pads. Part no 2-320-280-01 about US$16 each (not pair).
Old ear pads slip off - pull gently to stretch the part that sits in the groove of the headphones until one side slides out.
The creative sewer can remanufacture new pads from thin soft leather by following the pattern of the old ones.
No cost fix is to scrape off the remaining peeling urethane leaving the soft fabric backing. Headphones will still work but the soft earpads should absorb high frequencies.
Sep 12, 2012 | Sony MDRXD400 Professional Headphones
Ear pads falling apart
Please follow the proper instructions below
Ear cushion reattachment
If the ear cushions come off your headphones,
reattach them as follows:
1. Fit the mounting flange inside the rim of the ear cup.
2. Make sure it attaches smoothly and uniformly within the entire ear cup. (Do not remove the ear cup lining material).
Ear cushions may need to be replaced due to normal wear and tear. To order replacement ear cushions, call 1-888-865-2700.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 15, 2011 | Bose 41213 Headphones
I need replacement ear pads for Sony cordless headphones model -MDR-IF-140
Check out My tip on headphones, at the bottom of it you will find a link to a place that should have them. Just click my user name to find the tip.
Feb 15, 2011 | Sony MDR-IF140 Consumer Headphones
Need new ear pads
See my tip on replacing dodgy cables plugs on headphones. Just click my name. You will find the answer at the bottom of the page.
Dec 04, 2010 | RCA WHP150C Consumer Headphones
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Headphones
Mar 19, 2009 | JVC Gumy Ear Bud Headphone - Peppermint...
RCA WHR50 Consumer Headphones Logo
67 people viewed this question
Top RCA Headphones Experts
Are you a RCA Headphone Expert? Answer questions, earn points and help others
