Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
905080-11 BATTERY CMM1000 how quick can the battery be replaced?
How long does it take to replace the 905080-11 BATTERY 24 VOLT CMM1000 ?
I don't have one of these mowers yet but would like to keep spare back-up battery to finish my yard.
Know of a schematic anywhere?
Thanks
5 Suggested Answers
SOURCE: How to replace batteries on CMM1000 (diagram?)
I have a CMM1000 which needs new batteries. I have pretty much figured out how to replace them, but I haven't found replacements yet. Please let me know where you found them! You need to remove the (black) top cover - there are 6 screws involved. 2 screws are in recesses toward the front on top. You will probably need to remove debris to access these. They are Torx type, but if you don't have Torx bits, they have a slot which works with a flat head screwdriver if you're careful.  The next 2 screws are toward the back down at either side. These are also the Torx type and they have star washers. The last 2 screws are up in the charging area. They are regular phillips and they attach to the circuit board. With all screws removed the top cover will come free. Be gentle though - there are wires from the charging meter that are still attached. You have to maneuver the cover over the height adjustment handle, then flip it up to reveal the circuit board. Disconnect the red and black wires from the terminals marked "TB2 Fuel Gauge Red" and "TB3 Fuel Gauge Blk" The top is now free and can be set aside. There is a push-fit block of styrofoam which can be removed and set aside. You should now be able  access the battery terminals which can be removed with a nut driver or socket wrench.  There is a jumper wire also. Make a note of the polarity of all connections. At this point the old batteries should slide out from their styrofoam cradle (I haven't actually tried this yet).  From this point you will reverse the steps to install your new batteries. Hope this helps.
Posted on May 25, 2008
  • 313 Answers
SOURCE: Rechargeable lawn mower lacks power
just to let u know CMM1000 mower are on recall for pcboard.
if ur mower is type 1 to 4 then its the subject for recall for convertion to CMM1200.see ur nearest service center right away.
Posted on Aug 11, 2008
huffman49
  • 235 Answers
SOURCE: how do i change the battery in my b & d
look under the cover
Posted on Apr 12, 2010
richroth
  • 9472 Answers
SOURCE: I have a19" 24volt blackanddecker
Check all the wiring for corrosion and clean if necessary. Make sure all wiring to the battery are tight.
Posted on Aug 09, 2011
Can you change the gaucho 12 volt to a 24 battery for more speed.
its best to go to 18 volts, 24 is too much for the gear boxes
Apr 01, 2013 | Peg Perego Gaucho Rock'in
Task force lawn mower 24 volt battery
Battery Source - if it's made they can get it but usually they use 2 - 12V batteries and wire them in series to get 24V
Mar 23, 2013 | Garden
Bought unit last year...when charging battery for 1st time this year red goes to green fairly quickly but only lasts a few minutes when using trimmer
sounds as though the battery needs replaced, can check and see if it has a warranty on the battery. Hope this helps Tim
May 01, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Jun 01, 2009 | Black & Decker Black And Decker FS24C...
I had the same problem, the batteries are burned out, I know you can replacements at Home Depot but if you can wait try the interenet.
"Google" what you want.
Mar 01, 2009 | Black & Decker Black And Decker FS24C...
Rechargeable lawn mower lacks power even with replacement battery. Six or seven year old rechargeable Black and Decker 24 volt mower. Replaced the battery last year after it became unable to mow my...
Aug 09, 2008 | Black & Decker 19" Electric Lawnhog...
I need to replace a battery in the Black & Decker CMM1000 cordless lawn mover but I can't find any directions. Can someone help me?
The battery in my CMM1000, purchased in 2003, finally gave up early in the summer of 2009. I bought a replacement battery at the local DeWalt store for about $140 including tax. The original battery was comprised of two Panasonic 12Volt, 20Amp-hour units in series. The replacement battery is comprised of two BR 12Volt, 17Amp-hour batteries in series. To replace the battery, simply remove two Torx screws toward the front on top of the black cover and two more, one on each side of the cover down next to the orange base toward the rear. It is not necessary to remove the two screws near the charge indicating meter. Cut the first two or three tiewraps holding the "throttle" cable to the push handle so as provide some slack. Lift the black cover up and over the height adjusting handle. Do that and everything else to be described here while working from the opposite side of the machine. The cover will not come all the way off and it is not necessary for it to do so. It will lift up far enough to allow removal of two pieces of styrofoam, one between the battery and the motor, the other between the battery and the inside rear of the housing, and the battery. The battery is held down by a fabric strap that is attached to the base of the machine with a screw on each side. Remove the one opposite the height adjuster. The battery will then be "loose" except for the two electrical wires that connect it to the machine. Lift and rotate the battery so as to present easy access to the terminals. I used my B&D drill motor with the appropriate socket to remove the flanged nuts retaining the cables. The battery can be removed from the machine once the cables are disconnected. Reverse the above procedures to install the new battery. Important note: The throttle cable has to go under the front styrofoam piece... the black cover will not go all the way down until the cable is in the right place. One might be tempted to push harder and that could lead to real trouble, so be sure the cable is under the styrofoam. The CMM1000 is an excellent machine in my opinion, and the ton or so that it weighs provides a good workout for me that I personally enjoy.
Jul 30, 2008 | Black & Decker 19" Electric Lawnhog...
Replacement batterys for cmm1200 black&decker electric mower
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
466 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
