Question about Whirlpool Calypso GVW9959K Top Load Washer
After being plugged in nothing works on electrical panel. Have checked both the outside breaker and electrical outlet and both are in working order. Left machine unplugged for day and a half, plugged back in and still nothing.
  • rql3232 Jul 02, 2009
    Where is the control board?
  • 999 Answers
You need to verify the power is getting to the control board. If power is present on the board terminals the board has failed.
Eric
Posted on Jul 02, 2009
  • Eric Duda
    Eric Duda Jul 05, 2009
    Control board is in the console. It is what is on the other side of the buttons you push to operate the machine.
    Eric
Bunn BX-B coffee maker; When plugged into a known good electrical outlet there is no red light. Nothing like a fuse is blown. It made a pot of coffee then nothing. 4 years old.
Check the home panel circuit breaker first. Then plug the brewer in to another outlet. If that doesn't work, there is a chance that the switch is bad. Happens too often on Bunnomatics.
May 20, 2016 | Bunn Coffee Makers & Espresso Machines
Electrical outlets in my 98 skyline fifthwheel stopped working.but there's power going out of the breakers
This is an indication of a failed connection. Somewhere. Since you probably do not know how the affected circuit was run, it's going to take some time - but it's not difficult work. But before we roll up our sleeves - first locate and RESET any Ground Fault Interrupter (GFI) type outlet. If any fail to reset - replace it with another GFI outlet with the same electrical rating. Pay attention to which cables and wires that are connected LINE and LOAD terminals wires when removing and replacing! Don't forget to check outlets on the outside of the 5th wheel.
Circuits fail almost always at connections. Wires and cables in walls don't just "break" in the middle. We need to check connections in the bad circuit. First, plug lights in all the outlets. Turn the circuit breaker for the bad circuit from ON to OFF. Note which lights shut off. With the break OFF, check the outlets that WORKED.
We're looking for the point that power entered the outlet box, but due to a failed connection is unable to leave it and feed the first failed outlet. Check and tighten all screw terminals and wirenuts. Check both hot and neutral wires. Make sure no wires are loose, pull out or are burned (cut and strip back these wires and reconnect / wirenut). Try to power the circuit to see if you found the problem after each check - if not - repeat at the next outlet that worked until you find the problem. If you are still unable to get it working after checking the working outlets, repeat the process on each of the non-working outlets. If still unable to get it working, check ceiling fixtures as it is not uncommon to wire to the light fixture first and then feed down to outlets.
Feb 02, 2016 | Electrical Supplies
Need help with electric outlets not working
Unplug unit from wall, check breaker in main electrical panel, if tripped reset. Dont plug in oldsurge suppresor. Go to menards and buy a new one.
Feb 22, 2015 | Video Game Consoles & Games
I have 3 plugs not working in my garage. i have checked the breakers and gfci plugs throughout the house all are in working order. I am stumped
Dumb question but were they working before? I've been to houses to fix outlets that were wired around by previous homeowners and had no electricity going to them.
Jan 12, 2013 | Electrical Supplies
Plug the new fan motor, nothing
Sounds as if the Fan Switch may also be faulty. Or the new fan motor is defective. Is the flame function on the electric fireplace working? If the flame function is working, than obviously the fault is either in the fan switch or the new fan motor.
If the motor has a regular receptacle type plug on the end of the cord, try plugging it directly to a wall outlet and see if it works. If you're able to do that, then the problem is in the fireplace's fan switch or in the wiring circuitry going to the fan motor. Perhaps, this is what was wrong all along and not the fan motor, itself.
If nothing is working, check the wall receptacle that the fireplace is plugged into, by plugging in an electric lamp. If the lamp won't turn on, then there's a circuit breaker tripped in your homes circuit breaker panel. Check the circuit breaker panel for a tripped breaker and with nothing plugged into the offending receptacle, reset the breaker. Plug the fireplace back into the receptacle, turn it on and see if it trips the circuit breaker. If it does, there's an electrical short some where in the fireplace. Look for burned or frayed wiring, as well as bad connections.
Hope this helps solve your problem.
Feb 15, 2011 | Dimplex DF3003 Electric MidSize Heater
GE XL 44 gas oven not working. I replaced the igniter for the oven, but not the one for the broiler. Also replaced the regulator valve. Still doesn't work. I didn't replace the broiler igniter as we...
most newer models of gas oven require electricity in order to work. I would check the outlet where you have your oven plugged in. Plug something else into that outlet to make sure it is live. If it is not, check the electrical panel breaker or fuse.
Oct 29, 2009 | Kitchen Ranges
If your dryer was working and then just wont turn on after that, what could it be?
If it is an electrically heated dryer, check the dryer breaker pair in the house electrical panel--push off, then on. If the breakers hold, try the dryer again--if works, ok! If the breakers trip again, then the heater element in the dryer is likely shorted to ground. To service the elements, the drum must be removed.
If this is a gas fired dryer, check the electrical outlet with a working lamp. If nothing, check the breaker for this circuit.
Aug 28, 2009 | Dryers
Everything went black suddenly. plug works, tried plugging into another outlet nothing happened?
A circuit breaker tripped. If the breaker panel is outside do not go out if it's dark without someone with you.
Aug 07, 2009 | Microwave Ovens
Electric outlet does not work
LETS START HERE , MOST OF THE GFCI BREAKERS WILL SOMETIMES RUN THROUGH THE BATH ROOM OUTLETS AND THEN OUTSIDE IF YOU HAVE A GFCI IN THE BATH OR LAUNDRY OR BASEMENT OR GARAGE MAKE SURE NONE OF THE RESET BUTTONS ARE IN THE TRIP POSITION THE NEC CODE CALLS FOR ALL OF THE LISTED PLACES AS WELL AS CRAWL SPACES AND NEXT TO AC/HEATPUMP TO BE ALL GFCI AND TO SAVE MONEY AND WIRE MOST OF THESE ARE DAISEY CHAINED TOGETHER TO SAVE MONEY SO THEY PUT ONE CLOSE TO THE BREAKER PANEL AND FEED THE REST OFF IT IT WILL BE A GOOD CK I HAVE HAD MANY CALLS FOR THIS THROUGH THE YEARS
Dec 09, 2008 | Rival S12T Electric Skillet
Whirlpool Calypso GVW9959K Top Load Washer Logo
154 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
