Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
It connects but after a minute or more it resets itself
    Problem Solver:
  • 8 Answers
Another reason for this could be that you have DHCP enabled on your WRT54GXV1 and at the same time the modem or someother network device connected to the router also has DHCP enabled at the same time. Therefore, there is a "fight" between these two devices as to who will assign the IP address... as a result your wireless signal drops off after every few minutes. Hope this helped.
Posted on Jan 28, 2010
    Scholar:
  • 111 Answers
Possibly conflicting networks or devices sharing the same channel. I would "link" with the unit via RJ45 and change the frequency and channel to prevent any other interference.
Posted on Jul 02, 2009
How do i reset
Unplug it and leave if off for more than 30 minutes, it should reset itself...you also need to unplug all connection to it, basically, similar to when it was brand new.
Jul 04, 2014 | Medion MD 30262 32 in. LCD TV
How do i reset the cycle programme on my ADG 954 Dishwasher
Hello
Wait for five minutes if the motor stopped itself and has been stopped for less than 10 minutes. This occurs in the event of an overload. If this is the case, the dishwasher will reset itself in approximately 5 minutes.
Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
Repeat step 3. This will reset the dishwasher.
Aug 11, 2011 | Dishwashers
After reconnecting my battery wy does it take the car so long to reset itself back up
First your battery is low. Normally it takes up to a minute. Also disconnecting & connecting battery I HOPE you're connecting negative cable last. If you're not connecting negative last, you ARE damaging electronics with a power spike.
Mar 24, 2011 | 2001 Dodge Stratus
Shows error message 6000
You should try to reset the unit.
To reset first switch off the unit then Disconnect the unit from power supply/batteries then disconnect any other units connected to it, after that Leave it disconnected for 30 minutes. It should reset itself then start again.
Try this:
1.Press ON/OFF switch to reset the multifunction device 2.Removing paper jams MP600 3.The MP600 may require repair
Oct 27, 2010 | Canon Office Equipment & Supplies
When i go to connect it says TS ERROR INTERNAL !!! Pls help.
could be an issue with the connection or the router itself. try to reset the router and your system. turn off and turn on the router to reset it. may help to power cycle by unplugging the router for about a minute before you plug it back and turn it on again. you can also check the manual to see if it has a different way to reset the rouer settings.
Aug 30, 2010 | Computers & Internet
My Sony Grand WEGA LCD rear projection 51" turns itself OFF every 20 sek and turns itself back ON after every 35 sek. ???
Try resetting the TV to the factory settings. Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Televison & Video
I have hp printer 4700 color laserjet .i installed new image transfer kit but counter not reset automaticaly .plz help me how i can reset manually . thanks
What I recommend you to do is turn off the printer, disconnect it from main power for a couple of minutes and then connect back and then turn on and counter suppose to reset by itself.
Feb 27, 2010 | HP Color LaserJet 2600n Printer
Try to access yahoo mail & just shows cannot display web page.can access other web sites as normal
Restart computer and your internet connection. This should take care of the problem.
When you disconnect your internet connection, leave it unplugged for 5 minutes. This will clear itself and reset.
Jul 07, 2009 | Computers & Internet
Temperature sender
Try removing the battery cables so the computer will be reset. Leave it off for about 15 minutes. Then reconnect it. The computer will reset to the default settings. Every time the battery is removed and stays disconnected for 15 minutes or more, it will reset itself.
Jul 01, 2008 | 1998 Ford Escort
Connection drops with netgear router
You router needs to be replaced,, When it gets loaded, it resets itself as it isnt capable of carrying the load.. if you look at your ip when this happens you would have realised if your ip changes.. You can try resetting the router first but if that fails you will need to replace the router..
Jan 18, 2008 | Computers & Internet
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
147 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
