Question about Samsung SPH-M500 Cellular Phone
Delay in responding to buttons
When it goes in its battery saving mode and I flip it open it takes about 30 sec for the screen to light up. Then it has a serious delay in responding to any buttons.
Once it gets out of this state though, it works well for a while. As soon as I don't use it for a few minutes, it freezes up again and doesn't respond to buttons.
It just started doing this today.... It is fully charged, I haven't dropped it and it has not had any contact with water.
    Problem Solver:
  • 9 Answers
I have similar situation where mine started freezing for no reason.. I suspect faulty battery.. May need replacing and possibly, recall of battery.
Posted on Jan 15, 2008
Not used my netbook for a week it was fine when i turned it off now when i plug adapter in green light comes on but nothing happens if i unplug it then green light turns to orangy colour i plug it straight...
Unplug the charger, remove battery and then keep pressing the power button for 30 sec. Then wait for one minute, load the battery and then try to switch ON.
Apr 26, 2014 | Samsung N150 (36725723009) Netbook
When starting my Dell Inspiron 1545 laptop it always goes to windows boot manager screen and will stay there for 30 sec before booting up Any way to stop this or shorten the 30 sec delay to say 5 secs
go to command prompt (windows key and r)
typ mscinfig and press enter
click on the boot tab (2nd one)
lower right corner is a box with the timeout value, set it to the desired time and tick the box make all boot settings permanent save changes then reboot
Sep 18, 2013 | Computers & Internet
My IBM T30 Think pad lap-top is stuck in power save mode.The battery is still charging fine,but the whole screen is black with no image when i turn it on.However when i switch it on,all the leds light up...
Try to power drain the motherboard.
please follow this steps:
take out the battery
unplug the power adapter
press and hold power button for 30 secs
put everything back in
power on the computer
if issue is not resolved. There could be a possibility that this is LCD problem.
May 21, 2010 | IBM ThinkPad T30 2366 Notebook
2004 Passat TDI won't start
using the key,lock car/hold key over for 30 secs,then press/hold unlock button for 30 secs,that resets the alarm/immobiliser.OR does the pre heater coil light up orange then go out so that you can start car,or are you trying to start the car too soon or waiting too long after the light goes out.also try spare key,sometimes key looses code...as the pre heater is operated by opening the drivers door any delay...
have you tried wynns/redexe diesel treatment,could be dirty injectors.....
after trying all the above and you have no joy, come back to me, ta!
Apr 18, 2010 | 2004 Volkswagen Passat
When I turn my V6000 on, I have power lights and the fan starts for 5 secs then shuts off. Nothing appears on the screen!
Sorry to hear about your V6000 problems.
If this problem has just started and all was OK before this happened.!
1. Remove all media from drives.
2. Remove battery and A/C power input.
3. Flip unit over and remove the memory.
4. Disconnect the CMOS battery.
5. Remove the Hard Drive.
6. Flip unit over and Press the Start Button for 30 seconds.
7. Flip unit over again and re-install the Hard Drive, Memory and last, the CMOS battery.
Note ...
8. Reconnect the unit to the A/C input supply voltage.
Leave the battery out for NOW !.
Flip unit and try to start with the Touch Pad Led's. This should bring up Quick Play.
If your unit starts and you here several beeps,
Don’t worry, !! You should be able to access the BIOS screen. You can reset your date and time.
If you are still not able to start unit, drop me a email and I will try some other ideas.
Hope this works for you. !!
Try it, It may work !!
John Ray
john@johnrraycomputer.com
Readers please rate your information, even if you disagree, it shows the technician, you care enough to respond.
Thanks.
Jul 09, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
How do you fix a frozen flip video ultra?
I fixed mine! When I turned it on it only had the flip logo on the screen & it would only shut off if I took the batteries out. I tried everything - holding the on switch for 30 sec, holding the record button & the on switch for 30 sec, deleting every bit of data from the camera, reinstalling the software onto the camera, leaving the batteries out for a month... I took it apart & found a burnt spot on the motherboard. I scraped it with a pocket knife, put it back together & now it works like new!
Jun 23, 2009 | Pure Digital Flip Video Ultra Camcorder
Sony DSC H-5 Camera slow response time
you might have switched the shooting process to timer mode. please refer the instruction manual to change it back to normal mode.normally there will be button near the lcd screen with the symbol of a timer deviice. if you click it once it sets the delay of shot to 2 sec and for the second time to 10 secs.and for the third time, it goes back to normal mode. thanks for using fixya. please dont forget to rate my solution!!!
May 29, 2009 | Cameras
Sansa e250 wont turn on, help
I found the solution to our problem!! and it is very easy. Take the 4 screws off the back. Remove the battery. Press the on/off switch and all the others on the front. Replace the battery and the screws.
Mine needed to be plugged in again, but the computer could read the Sansa and I can see the screen again. Now it is charging and I think that the problem is fixed.
Feb 27, 2008 | SanDisk Sansa e250 MP3 Player
Black Screen
Can you shoot? battery might be low taking it to "save-power" mode. Try hitting "DISPLAY" to force the LCD screen to show.
Oct 23, 2007 | Cameras
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung SPH-M500 Cellular Phone Logo
67 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
