Dryer is less than 3 months old and digital panel does not operate, light turns on when door opened
    Sergeant:
  • 340 Answers
Sounds like you have a warranty problem should be covered unless ya bought it on craig's list. Tom
Posted on Jul 02, 2009
My indecit dryer just stopped working. Press start nothing turns, open door can hear a sound of whirring, slight burning smell
This is the forum for questions about Television sets. Try reposting in the section for washer/dryer queries.
Sep 02, 2014 | Televison & Video
Control lights come on briefly, then turn off, dryer will not run
make sure your getting 220v from the receptacle . good luck APPLIANCES R EN
Mar 02, 2013 | Maytag MDE4806 Electric Dryer
Screen don't work
If less than 3 months old the set is under warranty-- Any attempt to open or repair it will void the warranty.
May 24, 2012 | Sceptre 32 X320BVHD 32 LCD TV
LG 2301 dryer will not turn on but door light works
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2010 | Dryers
3 yr old LG TROMM DLE 5977W Dryer-loud rattling noise started about a month ago.If I press on the front of the dryer below the door it stops.Something has come loose that stopped the vibrating noise?How do...
Remove the bracket at the top rear of the dryer 6 screws
Tilt top up and forward to remove
Remove operator panel by unplugging connectors and removing screws.
Pull up and forward to remove front panel
Nov 06, 2009 | Dishwashers
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Operation light and timer light blink 5 times?
I don't know if this is the proper technical solution or not but my unit was having the same issue. I cleaned it checked fuses made sure the cover was properly in place and nothing worked. As a final thought I went to the home fuse panel and tripped the breaker for the unit, waited about 30 seconds and turned it back on. I did this with the unit set to off. When I came back and turned it on, it is working properly with the operation light solid red.
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Frigidaire GLTF2940ES3 door lock keeps clicking when open or closed and panel flashes partial digits
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Step 6 you should also access and save or print: OWNERS GUIDE, INSTALLATION INSTRUCTIONS, PARTS MANUAL, and OPERATING INSRTUCTIONS
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for viewing and printing.
Thank you and good luck.
Jun 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Maytag Electric Dryer - Control panel doesn't light unless door is open
the power connects for the 240 volts to the outside screws on the terminal block the center connector is the nutral connection
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
Frigidaire dryer
there are several issues that can cause this most common is the vent restricted backing up heat in the dryer if its as old as you say you need to check the whole vent system it has to be 4inches dia all the way if its mashed or drooping under the house its restricted if its folded over or mashed behind the dryer its restricted the thermal limiter is a safety thermostat it opens about 300 degrees to prevent fire the dryer has three thermostats an operating thermostat a safety thermostat and the thermal limiter if the operating thermostat fails then the safety thermostat takes over and cycles on about 165 on and off if both thermostats fail then the thermal limiter opens about 220-300 depending and it doesn't reset and cuts all the power to the dryer till a tech can check everything i just told you about so if your vent is clear and the best way to vent is 4inch pvc drain pipe 90 it up behind the drier then connect with a short peice of metel vent then just replace all three thermostats
May 21, 2008 | Dryers
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
