Question about Kenwood KDC-MP435U CD Player
I had to disconnect the power wire to my KDCpmp435U, there is power going to the stero but the deck will not power up
  • 43 Answers
Are you 100 percent positive that there is power going to the stereo, i have installed for years and sometimes i suprise my self on little things i miss,
check the fuse at the back of the deck make sure the fuse didn't pop
and check the fuse in your car fuse box to make sure you didnt pop that one either, write me back if these still arent the issues
Posted on Aug 05, 2009
I need to know which wire is the hot wire, going from the car to the car stero
red wires in auto electrics is the nominal power wire. Use a circuit light tester and if it comes on when the ignition switch is on, or in the accessories position then that is the hot (power )wire.
Dec 23, 2013 | 2001 Buick Regal
The red light in my stero stay on any time i put it on
Clearly the red light is a protection device. Sadly you have probably blown one of the main power output devices in the amp. If you know which channel the two wires that touched belong to, it will narrow which one has gone.
Dec 16, 2012 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
I hooked up a new stero deck and now the interrior lights are staying an and flickering and when i bought the jeep it had no owners manual so i need to know where the fuse is to the interior lights
Fuse locations vary from year to year and also with different models. A blown fuse will not make the lights flicker. First thing you need to do is disconnect power to the radio you installed and see if the problem with the lights goes away. If it does, find another power source. Do not tap into the heavy yellow wire under the dash if you have one. That should be for air bags if you have them and if so, you can accidentally deploy the bag if you tamper with it.
Mar 24, 2011 | Jeep Grand Cherokee Cars & Trucks
I'm trying to wire in a newer factory ford am/fm cassette player/cd changer in my 95 ford explorer but the plugs are slightly different and contain more wires, just need some schematics . The 95 came with...
go to a store were they sell car stero an take your radio an tell them u need a wiring harsent to plug in the radio an plug into the plugs on the car you have dont go to walmart the dont sell them its going to be from car stero store.
Jul 30, 2010 | 1993 Lincoln Mark VIII
I have a 1976 kenwood am fm stero receiver, the stero works great but just recently the face and power single lights went out, is their a fuse inside. I open the cover and did not see one.
A stereo or amp, either one should have a fuse, fuses for radios would be in the wiring harness behind the radio deck. An amp fuse should be obvious were they insert in the fuse blocks by the amps main power cable connector. If you see that all fuses are fine then check your ground wires if not then your radio is bad.
Jun 19, 2010 | Kenwood KAC-9152D Car Audio Amplifier
The power buttons doesnt turn off and is there a
there is a power button on your deck, but you must get to the screen where the clock is, touch the button and it will shut off, if not then we need to trouble shoot the situation, which is easy, if you take out your deck. and if you can find the blue wire w/ the white stripe that is located on your deck this is your remote wire, this cut the deck on and off, when hooked up properly, first your gonna need to extend this wire, so it can reach the fuse panel, then you need to locate the fuse that says cigarette lighter, pull the fuse out, and stick the extended remote wire there, then reinsert the fuse. now the deck should be off, now if you put the key in and turn it to on, the deck will come on, and when you turn the car off, it will swtay off, this will work i bet my rep on it.
Feb 19, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Deck turns off when i hit a bump in my car
A couple things...but the deck must come out to check. (assuming this is a 12v N.American car) If you cannot remove or you dont know how - take it to a car stero shop. Electrical fires are nasty!
  1. Make sure there are no open wires and connections are tight and taped (badly crimped connectors will hide loose connections)
  2. Make sure the deck is supported in the back-it should not wiggle around.
  3. There should be a wire firmly connected to the chassis of the car and the back chassis of the deck - Please do not drill into the deck - use an existing bolt !
Nov 07, 2009 | Pioneer DEH-1100 CD Player
I put the headdeck back in and pinched a wire have i blown the fuse in the stero or car fusebox? there no power in it atm the stero i mean
take it back out check for naked wires and if insulated good ,then look on back of the deck there should be a fuse if its bad replace it ,and check the fuse box under the hood and on drivers side under the steering wheels left side fuse box,theres 3 fuses usally to the stereo check them all.if my info was of any help to you please leave a comment thankyou.
Sep 02, 2009 | Kenwood KDC-MP228 CD Player
I just bought a used dual xd6210 stero deck for my car but i dont have the wireing manual for it. i need the wire color code sheet
there pretty simple red+ goes to keyed power wire. yello is the same keyed power wire.black ground. speake wire will be like two green two violet one will have black stripe that is the negitive solid color is positive green and green violet ant violet white and white blue and blue youll just have to figure out thr front and rear. blue wire is for amp remote turn on wire your speaker wires may be different colors but same idea
Jun 10, 2009 | Dual XD6210 CD Player
Stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
May 22, 2008 | Car Audio & Video
Kenwood KDC-MP435U CD Player Logo
61 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
