Question about Sony Handycam DCR-DVD108 DVD Camcorder
How do i delete video clips i don't want - Sony Handycam DCR-DVD108 DVD Camcorder
    Problem Solver:
  • 5 Answers
Select video footage list, select the clip you want to delete, press delete button/trash can, confirm delete.
Posted on Jul 03, 2009
Go to menu & delete it
Posted on Jul 17, 2009
I've lost my photos
Videos and photos are the best means to cherish good old days. At times due to accidental deletion of photos and videos or formatting of the memory card results in the loss of important clip. However, you still don't have to worry as Kernel for Windows Data Recovery tool provides you with a safe and risk-free alternative to get back all the lost or deleted photos and video files from memory card in every condition. For more info visit http://www.recoveryfiles.net/
Jul 20, 2012 | Cameras
By mistake I delete all my video clips can I get it back or restord it again?
Recover Deleted VIDEO CLIPS Files & Items Emptied From Your Recycle Bin. Retrieve & Restore Files Easily.
Aug 08, 2011 | Televison & Video
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
I want to delete a video clip which is downloaded by realplayer. But i am when i try to delete the video clip it shows - ' cannot delete : Access is denied Make sure the disk is not full or...
Do a search for the clip using windows. Once you find it. Right click on it and click properties. Look to see if it is marked as archive or read only. Uncheck the boxes. Then try and delete it. Make sure Real Player isn't running. You may have to log into administrator. Doubt it though. If it still won't delete. More than likely virus, or trojan, or ???
Hit cntrl+alt+del then start task monitor. see if it is running in processes. If so click on stop process. If that don't work, then search for Msconfig. Go to startup tab. See if it is in start up. If so uncheck it. Restart computer then start all over.
You will still have to open Real Player and delete the shortcut after you delete the video.
Good Luck
Jan 16, 2011 | Computers & Internet
Using DVD-RW. How do I delete clips after finalizing, downloading to computer, then re-inserting the disk. I get message saying I cannot delete after finalizing
using this type of disc even in video or vr mode recording, it is not possible to delete the clips after finalization. unfinalizing the disc may not help.the delete option is possible only when you delete the last scene immediately from the camcorder.for reference see p.14 of the manual.so clips in between the first and last recording would not be possible to delete.an option would be to use your computer.select only the movie files that you would like to put on a disc and use your burning application for that purpose.at least you get to choose the clips you want and would have the capability of compiling it on a regular dvd disc.hope this helps.tnx:)
Apr 15, 2010 | Sony Handycam DCR-DVD92 DVD Camcorder
Deleting unusable shots
you will be needing the razor tool to delete the unusable since. in which you can also split the video in to two or many parts.
Feb 18, 2009 | Pinnacle Studio Plus 10 Full Version for...
Need to delete memory
You need to remove the memory card from the camcorder and place it into a pc or photo shops computer. This will allow you to view the saved items on the memory card. You can then save these to disc and delete the contents on the card.
Jun 12, 2008 | Optimus DV-5040 Camcorder
I don't know how to delete a video clip when my disc has already been finalized. There isn't any 'delete' button that i can find. Please help me!!
If the disk is finalized you cannot delete any clips - hence the term "FINALize"
If it is a DVD-R, try unfinalizing and then deleting the clip.
Jan 04, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
373 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
