Buzzing on my Goodmans GHC-50 home cinema
There has been a buzz on mainly the sub woofer but if you turn up the sound you can hear a feint buzz on the speakers
  • sherifoo Dec 16, 2008
    I have a buzzing on the sub woofer which gets louder when I turn it up. I have disconnected all the speakers and tried the box in a different location but it still keeps buzzing. Can any one help? My local electrical shop is not interested.
  • 4234 Answers
SOURCE: 100watt sub
There is a problem wwith teh power supply or the amp section. Does the noise remain constant or does it vary in volume? The sub should have a level control, does the noise vary with that control?
Posted on Mar 20, 2008
  • 124 Answers
SOURCE: No bass...
One of a few things.
The fuse inside the amplifier section is blown.
The amplifier has died
The speaker is dead.
Best to return to the place you purchased the unit or contact Velodyne for service.
Posted on Jan 04, 2009
  • 75 Answers
SOURCE: sub woofer buzzes all the time
ur sub wont buzz due to bad speaker. either u have a faulty preamp or power amp. yes it can be repaired and will not cost much. if it is loud and annoying, get it repaired. sometimes subs emit low hum when powered up. this is the way the are desinged.
Posted on Apr 13, 2010
Testimonial: "Thanks, That's what I needed to know, so now I'll look for whats buzzing and not new speakers"
SOURCE: Athena AS-P4100 Sub Woofer - blown main fuse - who repairs these?
Sorry I can't solve your problem. I think the main fuse on mine is blown too. Can you tell me where it is located?
Posted on Sep 01, 2010
SOURCE: my kef psw 2150 sub
is probably faulty capacitors
you should check out this link:
Posted on Dec 05, 2010
No sound from sub
  1. Are the stereo speaker wires run to the subwoofer and out to the stereo speakers
  2. Make sure the notch filter is off
  3. Refer to the manual on line:
Nov 12, 2013 | Mordaunt Short Aviano 7 - Powered...
If i increase the sub woofer volume the voice distorts and gives a buzzing sound. it works fine on low volume
Your sub woofer is not mean for voice sound...check that you have connected the systen up properly and that you have put the sub woofer into its wn connection..if it is in the right connection the woofer could be blown.also try decrease the midrange hurts on the woofer
Jan 03, 2010 | Audio Players & Recorders
Buzzing sound coming from my jbl creature speakers no music
Try this Double click on the volume control icon in the system tray.Click on "options"--"Properties".Select Line-in and Mic.Mute them. I hope this solves your problem.
May 14, 2009 | JBL CREATURE II Computer Speakers
Kef Kit100 subwoofer buzzing
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
Jan 18, 2009 | KEF Audio KIT100 System
Buzzing sound from woofer when I plug in
If the woofer works fine when plugged into any other port, I would say that you have a connector on the receiver that has a loose connection or possibly a cold solder joint (poor or broken solder joint). RCA jacks can be stressed quite a lot especially if you use cables that have very tight connectors. The female RCA jack gets wiggled or twisted when trying to remove a cable and this causes solder joints to crack. I would have a look at that connector on the receiver..
Mar 02, 2017 | Panasonic CT-35SF23 35" TV
KEF KIT 100 Sub woofer continuously buzzing
send me a request to my email address and I send you a fix, Axel
Aug 03, 2008 | KEF Audio KIT100 System
Jvc rx-e100rsl home cinema control center
unless there are some other connectors that may be used, i would think that the issue would be resolvable thru the system settings menu, there may be a speaker arrangement setting somewhere in the menus. The Sub is a .1 setting like 5.1 or 7.1, perhaps even 2.1 where the beginning number is the speaker channels and .1 is the sub. I would think with the sub being on a mono channel it woul/should work with any setting. If there is any more info you could supply I will further research this issue and try to help you get the sub working.
Jan 27, 2008 | Audio Players & Recorders
153 people viewed this question
