Question about Mattel My Meebas Interactive Pet
Character won't move to middle of screen, goes to top and bottom fine.
My daughter had the same problem with hers there is no fixing it. I went to the mettel website and got the costumer sapport number and called it. once I got through the phone tree I got a tech person right away. After I briefly explained the issue he took down my info and is sending me a voucher for $25! We can either use it to get a new meeba or we can use it towards any other toy made by Mettel or fisher price! you should give them a call!
Posted on Dec 27, 2009
Mine too! I have changed batteries, Reset it. I have no idea what else to do. One said to push the screen when you slide it and one said to gently pull the screen when you slide it. None have worked. I think mine is defective.
Posted on Dec 25, 2009
Black spots tv screen goes away sometimes
Your tv has multiple backlights in it... sounds like one of your inverters are going. Don't be surprised when the tv stops displaying anything at all.
Dec 31, 2013 | Televison & Video
52" Samsung that the top half of screen goes black.
the HDTV has a heat-related problem check your fans. Do they remove heat? the vertical chips paint the screen from top to middle and, middle to bottom so; your top to middle vertical chip is overheating as is your video chip; that is why you have "glitter" in the back ground. get rid of the heat or, bye,bye TV.
May 20, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Only part of the character/letter is showing
make sure the ribbon is latched into place (should lock down) also check on the ribbon itself to make sure the print is in the middle of the ribbon and not on the very bottom, if the ribbon is locked down and types of the bottom of the ribbon, it is out of adjustment. if the ribbon looks ok, move the paper scale (the plastic piece on top of the platen) up out of the way, then push down sharply on the platen. if it moves down and clickes into place, it should work OK.
Jan 05, 2009 | Lexmark Wheelwriter 15 Series II...
My monitor works for a little while, then goes black.
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
OR
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
ebaysbammbammfran
Oct 11, 2008 | E-Machines eMachines Monitor E15T4
Left top and right top of screen curled, bottom middle of screen has a hump to it
Yes you need to repair the convergence circuit. If you know how to solder and use a meter this can be fixed easily by yourself. If you call a repairman to do it, it will run you $300-$500 depending on your area. Let me know if you can use a meter and solder and we can move forward with repairing you set.
Tim nolan
Sep 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Top & Bottom of Display "squashed"
if you have a spare video card ,toss it in and see if this is a non intragrted card try useing the on board card and see how it behaves with the factory VGA
Oct 24, 2006 | NEC Diamond Pro 930SB 19" CRT Monitor
Mattel My Meebas Interactive Pet Logo
360 people viewed this question
Top Mattel Toys Experts
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
