Question about GE JVM1490 Convection/Microwave Oven
Convetion heat not working
On a GE JVM1490, upon setting the temp it just goes but does not heat up? Does the heating coil need to be replaced?
Thanks for any help!
  • 2 more comments
  • leslie_chaim Jul 02, 2009
    I found the problem!
    Looking closer and gently tugging on the wires, I realized that they were simply burend off from the sta con that connects to the coil.
    Now, I need just two sta cons... Any idea where I could get these special sta cons?
  • leslie_chaim Jul 03, 2009
  • leslie_chaim Jul 05, 2009
    I then found the wires to the heating coil are brittle! So now I need to replace the wires (or leads) themselves!
    It seems to me that it's part WB18X10149 but HEY! I don't need the ENTIRE assembly! Just one part from that whole set! (Probably the 4th down on the right of part #1648 inhttp://www.appliance-parts-warehouse.com...
    Any idea how to break up part WB18X10149? (Also listedhttp://www.partstore.com/Part/General+El... and many more...)
    Thanks!
  • 56 Answers
Sounds like the magnetron is gone ...they usually have a 5 year part warranty
Posted on Jul 03, 2009
I have a GE Spacemaker Ovenover the range. JVM1490. There isn't a light that goes on with cooking anymore. Can't find how to replace it.
After disconnecting the power, you should be able to remove the control panel by removing a couple screws from the side or bottom. Once the control panel is removed you should be able to see the bulb.
Nov 05, 2017 | GE Microwave Ovens
GE Microwave PVM1790DR1BB light works but no fan and the turntable does not turn
I have this exact model with the same issue. I am a technician by trade on office equipment. I took the cover off where the door latches go in and there are 3 relay switches behind there. I adjusted the switches so the door latch would make better contact with them.
May 05, 2013 | Microwave Ovens
JVM1490 owners manual
GE has the manuals for their products on their support site: http://www.geappliances.com/service_and_support/literature/ . The direct link to the Use and Care manual for most JVM1490 Spacemaker Convection/Microwaves is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40345.pdf .
I hope this helps.
(note: you will need Adobe Reader or a similar product to read the manual.)
Dec 02, 2011 | GE SpaceMaker Microwave Ovens
Microwave acts like its working but doesn't heat. The convection oven works.
Most likely causes are a blown fuse in HV area of microwave or an open thermal protector or thermal fuse.
Less likely causes are failure of various parts in the HV area.
Due to the lethal dangers inherent in microwaves, servicing of these parts is likely best left to a professional. That said, if you are technically versed I can point you in the direction of some good resources for troubleshooting and repair.
Oct 21, 2010 | GE JVM1490 Convection/Microwave Oven
GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Broken door handle on GE JVM1490 900 Watts
Go to ;
http://www.appliancepartspros.com/
and enter the model number etc of your unit. Note the diagrams in the left-hand corner of the screen. They also sell parts. Tools will be simple screwdrivers and small wrenches.
Dec 26, 2008 | GE JVM1490 Convection/Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
GE JVM1490 Convection/Microwave Oven Logo
149 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
