Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Temp Alarm going off, when freezer seems to be cooling fine.
We bought a bunch of beef and had the door open for about 10 min to load the freezer yesterday evening. The meat filled the freezer. I shut the door and turned on the quick freeze and you could hear it kick on. 3-4 hours later the alarm was sounding, so I pressed stop on the alarm button. The meat seemed frozen. The next morning the alarm was going off again and I checked the meat and still frozen.... This evening still frozen and sounding again....
  • 4,070 Answers
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Posted on Jul 02, 2009
  • rberryj3 Oct 29, 2010
    We had he same problem, but how does this happen? Is the regulator broken? We did nothing out of the ordinary in the last weeks. The darn beeping noise will not end, yet everything seem fine and frozen. How do we stop the alarm? It's becoming un-nerving!
How tro restart my digital freezer?
Can you hear the compressor start? If not try the extreme freeze button. Check the condenser is clean and fan working ok.
Jul 24, 2012 | Frigidaire Freezers
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Have a small Kenmore freezer (31" high x 24" deep by 21" wide). It works fine as far as freezing, but it never cycles off. Just keeps on going and going, driving me crazy. I also continually hear a subdued...
the wooshing maybe the oil/freon migrating thru out the internal system...
The cycle depends on 2 things... t'stat operation and timer. The timer usually shuts off freezer every 6 or 8 hrs for 20 to 30 mins. But the t'stat (once it reaches desired temp. should shut off freezer every 15- 20 mins. for an average 10 -15. So 15 mins off min 15 mins on (that is if the doors is not open) you get my point something like that...
but the way you describe to me it sounds like the t'stat. set it at 1 if it dont shut off and you are absoultely sure you got zero degrees (use a temp. reader) then replace the t'stat
let me know if this didnt work then plan B
Mar 09, 2010 | Freezers
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Kenmore Freezer Temp. Alarm
You should get a thermometer to be sure the temp is what it should be. With out it is very hard to tell correct temp.
Aug 05, 2017 | Freezers
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 | Freezers
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
1,178 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
