Question about Garden
Turns over hard needs jumped will not fire off it back fires
  • 218 Answers
Hi..my name is Keith..and the two causes i can think of is..1.. the engine valves need adjusting or 2..the timing is off..i hope this has helped..if not please write me back and we will dig into it further
Posted on Jul 04, 2009
Will not start. engine turns over. fire is present
The rust on the exhaust will hardly inhibit a spark of the proper power. The spark should be a blue colour and jump with a sharp noise like a shot.
A graduated spark gap is the best way to measure the spark power. A modern engine ignition system needs to produce around 30,000 volts in order to start and run smoothly - that equates to a gap of around 3/8" or 10mm.
Oct 19, 2017 | 2001 Ford Taurus
Kindle fire hd will not switch on
Try a hard reboot:
To reset/reboot your Kindle Fire:
-With the Fire charged but unplugged from the charger, press and hold the power button for a full 20 seconds.
-When the Fire cycles off completely, press the power button once to turn it back on.
Sep 23, 2013 | Amazon Kindle Fire HD
My kindle will not turn on
Try a hard reboot:
Aug 28, 2013 | Amazon Kindle Fire HD
Blazer hard to start think time has jump
It is not likely that the timing has "jumped". Jumping time is more likely with timing belts on OHC engines. Your engine should have a timing chain with steel gears. You may have a faulty cam sensor, crankshaft sensor (usually when crank sensors go out you have no spark or anything), or module problem. Purchase a "noid" light to check your injector pulse or contact a local store that may alllow you to use their scanner.
Jan 25, 2013 | 2001 Chevrolet Chevrolet Blazer
My engine back fired on my way home and now it won't start it just turns over
if it died it sounds like timing chain is no good could you drive it home after back fire if not timing chian junk truck probably jumped a tooth
Aug 21, 2010 | 1996 Chevrolet Blazer
Furnace fires up then shuts right back down
Hi check out the pressure switch ,see if it it blocked / jump it out and see if it lights ,by jumping it out you can fool it into fireing up,on some models
Feb 28, 2010 | Goodman GMS90703BXA Heater
77 fxe kicker slams back when started and the clutch is pulled in . replaced thrust bearing and the kicker gear stop was snapped off.. replaced and re assembled per shop manuel..?
all kick starter kicks back when starting just give it a little keck like just push dawn on the kick starter to wear it just turnes over 1once than jump on it than it should fire without kicking back but kick it hard or it will kick back
Dec 05, 2009 | Harley Davidson FXD Dyna Super Glide...
Gas seems to be jumping around the gas fire pit
A gas appliance is not something that one should be self repairing without the proper knowledge and training.
If you think it has a problem with gas "jumping around the gas fire pit" it could indicate a leak somewhere that could build up and cause an explosion and fire with serious or fatal consequences.
I would turn off the gas supply and contact a qualified service person to have it checked out properly.
Oct 24, 2009 | Forest Natural Gas Fire Pit Black Marble...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
