Question about Tomtom ONE GPS Receiver
Inserting a SD card
I have an XL 30 Tom Tom. How do I insert a SD card into it?
    Scholar:
  • 111 Answers
Try this link for the correct information
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Jul 02, 2009
Im locked out and I cant remember the password my brother set up for me what do I do to unlock my tom tom one?
To reset your password try this. To reset your TomTom device, do the following:
1. Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
2. Remove the SD card
If your device uses an SD card, remove it.
3. Reset your device.
Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
4. Turn your device on.
Press the On/off button for at least 5 seconds.
5. Insert the SD card
If your device uses an SD card, insert the SD card.
Feb 07, 2010 | Tomtom ONE XL GPS
Display reads problem with map
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL 330 GPS Receiver
GPS unit is stuck on the main screen, and wont turn off
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
Tom tom wont work after connecting to the computer
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
then just copy ALL the files from the tom tom to your sd card
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work
Sep 17, 2009 | Tomtom One XL GPS Receiver
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
I have a tomtom xl and when i turn it on the unit rejects the sim card and as a on screen symbul of a man with is hand out with a red x through it .
If you have an SD card installed then
Remove the SD card from the tomtom
The card may need to be formatted properly first or re-formatted.
Formatting is better done in a card reader.
There are differing views but this method has always worked for me.
Insert the card in the reader,.
Using my computer or windows explorer right click on it and select format
Now connect the tomtom to the pc but don't let tomtom home run.
Exit TomTom Home if need be.
You now need to select your tom tom which will also show as a drive and may even show its own special icon.
Then just copy ALL the files from the tom tom to your sd card.
Once all the files are on your new card switch off the tom tom and insert the sd card and re-boot the TomTom
It should now work.
If not try the hard re-set in which you would use a paperclip to reset the tomtom. there should be a tiny hole on the underside of the unti.
push the paperclip in there (not too hard) while the unit is switched on
This would cause a reset to factory defaults (you may have to set home location etc)
You may also have to switch off and re-boot again for it to take effect.
Aug 28, 2009 | Tomtom One XL GPS Receiver
I tried to put an SD card in my tomtom ONE XL and now it won't do anything...it is flashing what looks like a hard drive and there is a red X over the picture of a hand.
Remove the SD card
It should now work
Aug 26, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Tom tom one xl memory key
It's a standard SD card that you can get from electronics or camera shops. 1Gb should be OK.
Peter
Mar 05, 2009 | Tomtom One XL GPS Receiver
Tom Tom XL
The One XL can only read from internal OR sd card...
So, if you want the device to boot from the sd card, it need system files installed on the sd card...
So, try this:
- BACKUP !!
- Copy ALL content from internal memory to sd card.
- Insert sd card, and boot the device.
It should know boot from sd card, not internal memory...
May 05, 2008 | Tomtom One XL GPS Receiver
Tomtom ONE GPS Receiver Logo
66 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
