Question about Humminbird Matrix 12 Fishing System
Hi, I have a Matrix 12 Sounder and the depth reading is always way over reading. eg in 24 feet it registers 867ft?? the sysytem recognises the transducer. IS the reset or similiar to solve this problem? Thanks
Ihave the same problem
Posted on Aug 05, 2009
  • jgarvey8 Aug 05, 2009
    I am having the same problem. Any idea what caused it
How many square foot of floor panels do I need to cover a room 12 foot x 6 inches x 13 feet in square eet?
To convert your 2 dimensions to square feet you have to multiply them together.
12.5 x 13 = 162.5 square feet.
You do not give the size of floor panels you want to use
To find out how many panels you neeed, divide 162.5 by the square footage of the panel
eg, 12" x 12" panels are (1x1) 1 square foot so you would need 162.5 of them.
24" x 24" panels are (2x2) 4 square foot so you would need 41panels
Aug 15, 2015 | Building Materials
How many gallons of water in a 24 foot round pool that is 52 inches deep
18,600 gallons (length x width x depthx 7.51 =gallons)
Aug 23, 2014 | Pool & Spa
..no depth reading. Old transducer cable was
Hi, Check for debree on depth sensor under boat. As you said check for fuse(s) Good luck.
Jun 20, 2011 | Garmin 185 Sounder GPS Receiver
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
I need to know the cubic feet of my upright frost free frigidare freezer Model # MFU17F36W6
get a measureing tape measure inside dimensions multiply them together eg: a freezer with an inside dimension of 2' X 2' X 3' would equal 12 cubic feet if want an exact value measure in inches 24" X 24" X 36" = 20736 and divide by 1728 will give you cubic feet cool eh.. where did I get the 1728? (12 X 12 X 12) =1728 converts cubic inches to cubic feet Good Luck let me know when you pour that cement pad for under your shed I tell you how many yards to order
Oct 23, 2009 | Freezers
Unable to track the bottom
I think you need to level the transducer. You have it pointed way out in front of you so that when you're going fast it is able to bounce the signal off the bottom and it comes back to where the boat has traveled to. When you're going slow you're bouncing it out in front of you but it comes back up in front of you. Sorry but I can't find a picture of a Garmin transducer. Hope this helps.
Jun 02, 2009 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Depth sounder problem
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Jun 18, 2008 | Furuno GP1650DF GPS Receiver
Si-tex cvs 106 mk11echosounder
To re-program the Si-tex CSV-106 depth sounder to feet/meters/fathoms: Push and hold down the MENU key while turning the unit on (POWER key) to enter a special menu. Release both keys after you hear two beeps, almost immediately. Use the LOWER ALARM key to select the desired unit for depth, then turn off the depth sounder. That's it, just turn on again to see the change.
There is also another menu (for testing sounder) available by pressing the MODE and turning on as above.
Apr 26, 2008 | Computers & Internet
Log and trip function not registering
It is unlikely the problem is in the A65 screen.....most likely it is an issue with the paddlewheel itself, its circuit in the depth/speed transducer, or least likely, in the DSM25 sounder module.
Both the log and the trip functiions are read from the paddle-wheel sensor of the connected DSM25 sounder module and transducer.
1. Make sure you have a DSM25 sounder module and transducer with a paddle wheel (the A65 is available without the DSM25 option.)
Double check the connections between the DSM25 and the A65, as well as the transducer connection to the A65. There is an indicator light on the DSM25 to confirm it is on.
2. Make sure the paddle wheel turns freely. They tend to get fouled easily with debris and growth.
3. Make sure the A65 is giving to a reading for SPEED when underway or when having a buddy spin the paddlewheel by hand. Do not confuse SPEED with SOG. SPEED is from the paddlewheel.....SOG (Speed over ground) comes from your GPS sensor and is not used by A65 for log or trip purposes.
If you get npo speed reading at all the paddle wheel may be defective or the depth/speed transducer may be defective. See your dealer about a replacement.
Nov 06, 2007 | Raymarine A65 Combo GPS...
Raymarine C120
I don't have the sounder so can't address your question directly, but you can download all Raymarine manuals for your gear directly at www.raymarine.com
Aug 23, 2007 | Raymarine E120 GPS Receiver
Humminbird Matrix 12 Fishing System Logo
313 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
