Ge wireless Batery Opereted chime 1601s
The ge wireless push button GE1641 is damage. Were I can by.
    Scholar:
  • 111 Answers
From what I have researched it is cheaper to purchase another unit. Here's a link I hope this helps.
http://www.smarthome.com/2042/2-Entry-Plug-In-Wireless-Chime-Wireless-Doorbell/p.aspx
Posted on Jul 02, 2009
I have a GE Profile Series PYE22PSHSS 22.1 cu. ft. Counter-Depth French-Door Fridge. The door adjar alarm used to sound off a chime (which I turned on and set to high in the settings). It has suddenly...
Hey I get it understand what you're asking about the alarm can be disabled by pressing a sequence of buttons at the push-button controls on the front of the fridge I don't know exactly which ones they are but if you look for the alarm it'll be written sideways and small near the normal button
Mar 07, 2018 | GE Refrigerators
GE wireless door 19216/ST-66
They pick up signals from taxis and tow trucks. One some you can change the channels. Unfortunately the problem of 'wireless'.
Jan 29, 2018 | GE Home Security
Program simon security system chimes
To turn the chime on for your door/window sensor on a Simon 3 panel push the "chime" button on the keypad. Hope that helps!
Oct 27, 2012 | GE Security Simon 3 Wireless Home Security...
Friedland Evo Wireless Door Chime and Push Problem
While this is a little bit of a stab, if you replace the batteries in both units, do it at the same time, If the batteries are known good ones, simply take them both out and let the units sit for about 5 minutes before you put them back in. Make sure the battery contacts are clean and devoid of corrosion. Put them back together without pressing the button. I assume it is of the newer "self learning" style. In which case, hold the ringer button down until the chiime goes off.
If it is one of the optical greeters, there would be a setup switch position that allows you to focus/align the reflector for the greeter. Usually it keeps chiming until the alignment is correct whereupon it shuts off when things are right. Then you reset the switch to normal. If no switch for set up at all- just follow the same procedure until it stops. You can usually "eyeball" them pretty close without effort.
Dec 30, 2011 | Home Security
GEXL44 burners light with match, but not with electronic ignition
if u push the knob there is a clicking sound, if no the problem is damage the ignition coil, need to replace it,or check the outlet,plug or its batery operatet ignition? replace the batery.
the ignition is power operated,check the power source.
tnx gerbee
Jun 22, 2009 | GE Profile JGP636 Gas Cooktop
Door chime code for GE model 1601S &1602S
Hi there. I think I have the same GE chime. It has a series of 4 dip switches on the bell (base) and also in the switch unit. Just make them the same. On mine for example, switch # 1,2 & 4 are up (on) and #3 is down (off). Any combination of 16 codes should work as long as both units are the same. Just as an aside, I had a problem with mine working intermittently, then mostly not at all. It was the actual pushbutton switch inside the button unit. Luckily, I replaced the micro-switch and it's working again. Also during cold wet weather, the 12v battery gets depleted faster than normal probably due to moisture inside the switch unit. I taped a piece of plastic from a sandwich bag over the switch unit to help keep water out.
I hope this helps.....
Nov 22, 2008 | Home Security
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
90 sec count down
You Can Turn off the panel beep under the cover that is what i did.
Apr 15, 2008 | GE Security Simon 3 Wireless Home Security...
GE simon security system
Depends. Do you mean the chime? If all that is missing is the chime whenever a zone is tripped then simply press the CHIME button on the front panel. If it is lighted solid red then your chime is on and it will talk to you. If chime is off then it wont talk to you at all when a zone is tripped. Good luck.
Mar 09, 2008 | GE Security Simon 3 Wireless Home Security...
Computers & Internet Logo
441 people viewed this question
Alun Cox
David Payne
David Payne
