Question about Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM, 60 PSI, 12 Volt
Fimco 15 gal Sprayer, 12 volt, No power
Fimco 15 gal Sprayer, 12 volt, motor suddenly stopped completely. Acts as if no power. No sightable reset switch or fuse. Any thoughts?
    Problem Solver:
  • 6 Answers
Cross the wires on the pressure switch, if it runs then, replace that switch is all!
Posted on Aug 21, 2009
  • pauldo70 Aug 21, 2009
    pressure switch is stuck. cross wires on it, and if ti runs, replace that switch
Pump sprayer has no suction
We have the exact same sprayer 2.1 GPM for our FIMCO and the engine runs but it will not suction. This happened once before last year and because it was under warranty they replaced it. Now it is happening again but FIMCO will not stand by this part because they don't "Warranty their warrenties.". What a bunch of ****! Stand by your products for pete's sake!!! If anyone has any solutions or ideas it would help us out a lot!
Apr 14, 2012 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Can't get the pump to power on. when turn "on" nothing happens (no pump running)
MAKE SURE YOU HAVE POWER TO THE BACK OF THE MOTOR , IF YES IT MAY BE THE PRESSURE SWITCH IS BAD OR THE BRUSHES ARE WORN OUT. .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Motor runs but does not take in water
If the polarity of the voltage (+ and - ) are reversed, the pump will run in reverse and it will not pull water. Reverse the leads.
Sep 16, 2009 | Fimco 15 Gallon Spot Sprayer with a 12...
Fimco 15 gal sprayer has lost prime
There is an o-ring inside that is probably bad. I tore my pump apart and found it and repaired it. My sprayer was about two years old as well.
Jun 29, 2009 | Fimco On Demand 12 Volt 1.0 Gpm Pump
I also have a FIMCO 15 gallon 12 v spot sprayer, won't prime
I use an emulsifier with Round-up to make it stick better to the weeds (Sticky Spreader). The emulsifier had made the solution less viscous and was not moving through the wire mesh filter that comes out of the bottom of the tank. I removed the filter and it works fine. I have a filter in the handle anyway so there is no need for two filters for my application.
Jun 05, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco Sprayer , 25 gallon, 2.1 gpm, 12 Volts - Blowing fuses
Soiunds like you either have one of two things. Either the pump motor is bad or you have a wire that is shorted out. look for chaffed or bare wires or burnt spots on the sprayer and the machine towing it. one of the two is your issue. Hope this helps!
Sep 19, 2008 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM, 60 PSI, 12 Volt Logo
400 people viewed this question
Top Fimco Garden Experts
lnbn1975
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Are you a Fimco Garden Expert? Answer questions, earn points and help others
