My htm t9500-b is not working properly its moving very slow. often times it starts working by itself. I scanned it using avg anti virus it keeps on saying that 4threat are found an when I tried uninstalling them it wont happen
SOURCE: uninstall of software
Sounds like you did not do things in the correct order or you did not reboot between the AVG uninstall and the Kapersky install, so that it looked like AVG was still loaded.
Since Kapersky is not installed, the best way to proceed is to start from a fresh reboot, download and re-install the AVG free edition to get the registry entries corrected. Don't bother with updates as it is coming back out again. Reboot and uninstall AVG. Reboot again and verify AVG is gone before attempting to install the Kapersky.
AVG free can be downloaded from free.grisoft.com assuming you mean the 8.0 version, not 7.5, otherwise try downloading from www.filehippo.com and select the older version.
SOURCE: how will i remove the virus manually?
i hope you got norton off your system before putting AVG free on. Virus programs try to fight off other virus programs by postiong false virus claims to erase the other program. eventually they will kill your hard drive. You need a product key for a good virus protectant. Norton or CA offer good, reliable protection for your dollar. What i would do, is back up any really important stuff you have there, format your hard drive and install Vista again if you have the disc and then re-install it to permanetly delete viruses. Also your system maybe slow because VIsta needs at least a dual core processor and 2 GB RAM to work like a XP machine
SOURCE: my anti virus was expired,
ok, press f8 on startup and you should have a menu appear , select safe mode,
Now once booted select AVG scan, a command window will open and a scan will take place,
This should solve your problem,
Regards
GeWiz.
SOURCE: very slow
AVG is anti virus and works well I think your pronblem is a spyware one. So you need to scan it with an antispyware program, AVG have one of these too but there are a number of other free oines out there too
MALWAREBYTES Not free but an excelklent product use the free scan option to check your pc out.
please rate my help++++Thanks for using FIXYA
SOURCE: i wanted to use another antivirus different fron
I had the same Issue the other day but i found the Sonicwall Mcafee antivirus which is perfect for me. It auto updates to the date that you are using the Computer once you have internet your antivirus is always protected and antivirus definitions up to date.
