Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
How do u get the blade going to cut grass - Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
PTO button pull to engage blades push to disengage.
Posted on Sep 14, 2009
  • 61 Answers
There should be a lever or switch that will make
blades turn..
Posted on Sep 06, 2009
Cant get blades to full RPM replaced all idlers all belts greased spindles new elec. clutch new blades when cutting grass it leave rows of uncut grass
if the blades wont get up to speed or not cutting grass you have a belt that is slipping. could be the pulley is damaged or just a worn out belt. if it is leaving a strip of uncut grass you have a blade that is wore down on the ends not cutting the full path
Aug 05, 2017 | Garden
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Honda hrb536c
Tony you may be cutting too much too soon. Try running over the grass slowly with the back guard opened slightly so any grass can still spill onto the ground. When youv'e done one run put the grass box on and go over half a width of the mower at a time but start on a reasonable height.
Apr 22, 2014 | Garden
Mower is not shooting the grass out when using the mulcher. I have to clean the grass out when cutting the grass.
Maybe the grass you are trying to MUCLH is a little too high. Mulching doesn;t really cause the machine to "shoot" out the grass the way conventional cutting with a conventional blade does....it is the type of blade that when spinning, creates air pockets under the deck that allow the blades to keep cutting the grass over and over. Switch to a different blade to get it to shoot out.
Aug 13, 2010 | Black & Decker Garden
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
Riding mower
If the grass is very tall (more than 10") you will have to slow down to less than 1 mph, if you have a mulch kit on this unit, remove it to get the grass out as quickly as possible. Also, sharp blades & a level deck are important.
Sep 23, 2009 | Garden
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
Apr 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
300 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
