Question about Sharp AL-1641CS Laser Digital Copier
L4 Code I have an error code L4. I turn the switch several times and cut the power on and off. This still does not clear the code so it can operate
  • Anonymous Dec 21, 2007
    L-4 code
  • 29 Answers
L4 code error the main motor are not working properly.Replace the main motor unit.
Posted on Feb 26, 2008
You have to unlock the machine from the bottom part of the scanner there is a littler lever .if the lever is unlocked try with the folowing this take off the glass then clean and lubricate the shaft
where the carriage is back and fork
Posted on Nov 09, 2007
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
Error code 88 88
The 88 88 code indicates a modem communication error in the refrigerator. This error is not applicable in the U.S. It should be ignored. The control will conduct a self diagnostic check when it is powered up. When this code is encountered it will just need to be cleared and the refrigerator will resume normal operation. To clear the code, press and hold the POWER FREEZE and POWER COOL buttons simultaneously. NOTE: Be sure to press these two buttons at EXACTLY the same time -- no sound will be heard when the buttons are both pressed properly). HOLD the buttons down for about 8 to 12 deliberate seconds until the control beeps and goes blank. Leave the control in this diagnostic test mode and allow it to exit after it times out in that mode. This will take several minutes. When the test mode clears the fault code 88 88 and returns to normal operation, you should be able to set the controls on the unit and it will work normally.
Frank V.
Jul 22, 2012 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Error msg E000001-0000 What can we do
that is a thermistor error code. there are several causes for this. the thermistors are dirty, the upper fixing roller is damaged or it might have paper wrapped around it, or the connecter on the back of the fixing frame has a hair line crack in it. now you can clear this code if you you think there isn't anything wrong with the afore mentioned items.
you have to get into service mode. first you will have to shut the copier off at the main power switch and turn it back on once the error code pops up on the screen you will need to get into service mode.
you hit the
additional funtions button
then the 2+8 at the same time
then additional funtions button again
once in service mode you will need to follow the following steps
hit the copier tab
then the funtions tab middle of screen across the top
then hit the clear tab
then the err tab and hit the ok button to clear error
now you only have like 30 seconds give or take to get into service mode and to clear the error code before the machine shuts down if you don't get in fast enough dont worry shut the copier off and turn it back on and keep trying till you get in and clear it. trust me it took me several tries my first time i realized this myself.
Aug 16, 2010 | Canon imageRUNNER 5000 Copier
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Dec 16, 2009 | Sharp AR-M455N Copier
Sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed. Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Feb 03, 2009 | Sharp AR-C270 Color Copier
Error L4
This Code shows a mechanical problem. Main Motor doesn't run, or run slower. See gears.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error L4
l4 if sub code is 01 .check sub code by pressing start key .that is for main drive motor and gears .just check all main drive properly mian jee
Jan 15, 2009 | Sharp AR-5320 Black and White Copier
L4-05
Yes , main motor lock trouble , try to turn on & off several times quickly ! There is a load in the drive (stuck) look for paper jammed in paper path . need make & model to help further .
Mar 12, 2008 | Sharp AR-C160 Color Copier
Sharp AL-1641CS Laser Digital Copier Logo
447 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
