Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dimension 5150 won't boot
I switch my computer on & all it does is buzz six times. Power light stays on but nothing else happens.
  • 5 more comments
  • wilshb Nov 10, 2007
    Tried pressing f2 and f12 - no joy I'm afraid. There's nothing on the screen at all - like I said, the computer buzzes six times and apart from the green light being on and the fan, there's nothing.
  • wilshb Nov 11, 2007
    Checked monitor & that's OK. I think it's definitely the PC itself because this buzzing never usually happens. The same problem occurred one day last week - all I did was switch it off and try again & it was OK, but now it's gone completely. Not sure what to do now!
    Would you believe I tried it again this afternoon and it works now? I haven't done anything - so I guess it will go again soon!
  • Anonymous Nov 27, 2007
    i WANT TO REBBOT MY DESKTOP
  • Anonymous Nov 13, 2008
    It buzzes 6 times then nothing happns the fan and stuff are working but the monitor and keyboard and mouse don't respond, the computer just doesn't do anything else
  • Anonymous Mar 16, 2009
    5150 will not boot
  • Shoib Chandran
    Shoib Chandran May 11, 2010
    HI.Dell systems do have specific colors for the lights.Please let me know what is the color of the power button light on the system and the Monitor.If the light on the system is blinking amber/orange then it could be a case of Power supply.Also tell us whether u find any number 1234 it up on the tower just below the cd/dvd drive
It is probably your power supply that is going. That is what happened to my machine. Check that the fan is on on your power supply. If it isnt then your power supply is going and you will need to replace it. My computer lasted another couple of days before it died again
Posted on Nov 21, 2007
Backup! and be prepared when it happens again
Posted on Nov 11, 2007
Have you checked your monitor or monitor connection is there anything on the screen at all?
Posted on Nov 10, 2007
Check your hard drive I think press f2 or f12 for hard drive test or reboot. If it is the hard drive and its out of warranty check w/new egg just bought one for my 510 dont forget to check hrd drive connection type ata or sata good luck
Posted on Nov 09, 2007
Dimension E310 6 beep
if the beep pattern and led light pattern it's a memory problem, try reseating the RAM. Problem and solution is described multiple times here
Dimension E310 won boot up 6 beeps
21.June.2015
Apr 18, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 wont boot past post. I've tried afew things but nothing works. can you help? thanks
If it won't go past POST then there is a hardware error. Try removing the hard drive and RAM. The mother board should complain at power on giving messages. If it does, try fitting the RAM module by module, then the hard drive.
Apr 17, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a Dell Dimension 5150 Desktop Computer. I leave it on for hours on end and it has become extremely noisy from time to time, even when I am not actually using it. Recently it has become very...
There are several reason for this issue.
1. Power switch on CPU(Tower) might get locked while pressing.
2. SMPS might be old one.
1. Need to check the Power switch with the help of Multimeter.
2. Need to change the SMPS and check whether it is working.
Nov 01, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
When I start my computer it buzzes at me and the number 1 light stays on. I have tried removing and reintalling memory modules to no avail. This has been happening for months, but now it won't boot at all.
HERE is a link directly from Dell to what the diagnostic lights mean and possible solutions. Looks like it may be a memory issue but further troubleshooting will tell. Dell is usually pretty good about support even if you PC is out of warranty. At the very least they can help you diagnose the problem.
Aug 30, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 sleep mode
Perhaps, not the best solution. However, it should get you going. Hold the power button for 15 or more seconds. The machine should then power down. You should then be be able to reboot. If that does not work, remove the battery and the power cable. Reinsert and then boot the machine. Make sure that you let it scan the disks to fix any disk errors.
May 14, 2010 | Computers & Internet
Dell Dimension 5150 Boot Problems!
You can probably try two things here.
1) Go to the BIOS and reset the defaults.
2) Clear NVRAM from your Dell computer. Here is how you do it.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=4C1BF720A3E78F92E040A68F5A2811BE&journalid=7788D9829DCAA7C8E040AE0AB6E12FA2&Query=bnZyYW0=&SystemID=DIMENSION+5150/E510&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 boot up difficulties - just goes to the Dell screen and then nothing - a little blinking white dash in the upper left corner. I usually hit f12 to boot from there, but it seems that...
try to run diags, press f12 when booting the choose utility partiton. check for any error on your HDD but it seems like its an OS issue so all you need to do is to uninstall and reinstall your OS
Sep 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 - solid amber light at the switch.
Make sure the 12v power connector is securely connected to the system board. If you open up your computer look at the end of the board that the memory modules are there is a 4 pin connector thats the 12 v Make sure thats plugged in and secure, If thats ok you have already did the removal of the memory and replaced them, take out any pci express cards and use your onboard video, if that don't work try one memory module at a time see if that works you already seem to be savoy enough to do that and try that, and if that does not work you may need a new power supply. You can check it but probally will be bad I have the same desktop and thats been a problem with these 5150 along with the mother board going out after the warranty expires. I sure Hope this helps you out,, Happy Holidays to you and yours. Hey If you need me to look anything else up let me know. Thanks again bear001
Dec 15, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
235 people viewed this question
Alun Cox
