Question about HP Officejet 7210 All-In-One InkJet Printer
HP Officejet 7310 printer error Remove & Check Cartridge On Right
Keep getting the Remove and Check Cartridge on Right error on the black cartridge. This is a new HP ink cartridge and I've cleaned the contacts on it and the printer where it inserts. Re-inserted over and over and keep getting the same error.
  • harleydwi601 Jul 03, 2009
    None of those solutions worked. I got out a flashlight and examined the area where the black cartridge plugs in and it looks like I have physical damage on the circuit contacts on the carriage return that the black cartridge contacts mate up to. That must be the source of my problem instead of a software or cartridge issue. Not sure if it's cost effective to get it repaired.
  • HP Master
  • 13,433 Answers
Do you still have your old cartridge and does the old cartridge give the same message? If you receive the message with any cartridge the problem is not related to the cartridges.
Go over this page and follow the instructions exactly
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423559&lc=en&dlc=en&cc=us&product=391182&rule=21016&lang=en
If the problem is not solved you will have to service the product, the printcartridge carrier or its controller is not functioning properly.
Before sending the unit to service there are few things you can try to reset the machine.
Partial reset:
a. Unplug the power cable from printer when the printer is powered on.
b. Press and hold # and 3 while plugging in the power cord.
c. Wait until "partial reset" displays.
d. Answer questions - Language/country
Semi- Full reset:
b. Press and hold # and 6 while plugging in the power cord.
c. Wait until "Semi full reset" displays
d. Answer questions - Language/country, etc.
Full Reset:
a. unplug the power cable from the printer when the printer is powered on.
b. Press and hold # and 9 while plugging in the power cord.
c. wait untill "Initializing Full Reset" displays
If noting has helped then the problem is hardware related and the machine needs to be serviced. Contact your dealer or HP for warranty or out of warranty repairs. Warranty repairs are free.
Posted on Jul 02, 2009
  • Ekse Jul 03, 2009
    That has to be the issue.
HP 7310 black cartridge keep getting error
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
http://h30434.www3.hp.com/t5/Other-printing-questions/HP-K5300-not-printing-black/m-p/376191#M26084
Dec 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Remove and check cartridge on right. I have removed it several times but still comes up with message and will not work
All I did was replace my black ink cartridge with a new one and it works. You think it would say replace ink cartridge instead of remove and check cartridge on right. Good Luck.
Aug 14, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310 black cartridge error message
the clip on the side came out i put it back and i saw puncture in that pins plate in the printer maybe is a scratch when that spring clip come out itry turn on and off and put back the black cartridge but i receve same message to remove and check black cartridge?
Apr 26, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
X-spring tab broken in ink receptacle (HP officejet 7310)
I think you right. There are a lot of small parts which are finely tuned in a printer and most likely something else is still affected.
You probably are better off purchasing a new unit, unless you have the time and patient to figure it out.
Good Luck!
Sep 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Ink cart error
Is there a metal wire (clip) hooked on black plastic in the ink carriage? If not, these are notorious for breaking the small plastic hook....when broken, the cartridge is not held in proper postion so printer won't recognize that the ink cartridge is installed......no replacement parts are available for this series of printers.
Jun 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I keep getting the error remove and check cartridge on right even after replacing cartridge
Thank you for contacting Fixya Support.
Take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer.
May 06, 2009 | HP Officejet 7310 All-In-One Printer
Error message-remove and check cartridge on right
use a eraser on pencil and rub the contacts on both the cartridge and the machine try again i assume you are using new cartridges by hp
Jan 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Remove and check color cartridge
the internal circuit of the printer which connects the colour cartridge is gone faulty so this error.that internal circuit needs replaCEMENT.thanks
Dec 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Trouble installing new print cartridge
Make sure the power is on, and the shield drops, so you can access the black cover.
Sep 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
434 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
