Question about MSI MS-5185 Motherboard
Computer Does not work correctly with Radeon 9250 Graphics Card
I have an SEL 400 Gateway Desktop computer with a MSI MS 5185 Ver. 1 Motherboard installed. This board has the Aladdin V chipset (UGH!!!) with ATI Rage Pro Turbo AGP 2X integrated graphics. Several of the PC games I like to play will not work with the Rage Pro Graphics. Other than this, the computer runs absolutely fine. So, I installed an ATI Radeon 9250 PCI Graphics card. This card works perfectly in every other computer I have ever installed it in except this one, and one other computer I had which contained the Aladdin V chipset. What happens is this-When the Radeon is installed in the Gateway, it takes at least seven tries to get the computer to boot up before it finally does so. The first few tries it goes to the Gateway splash screen, then either puts the monitor into standby mode, or it just goes to a blank black screen. Usually, after six or seven tries, it FINALLY boots up, then everthing runs perfectly. I'm running WIndows XP Professional SP 2, and the motherboard has a K6-2 500 MHZ AMD Processor (Upgrade from the old AMD K6-2 400 MHZ Processor) with 384MB Main Memory (Up from 64MB), and two small hard drives (4 and 13 Gig. Up from single 3.6G) What would be causing this, and how do I fix it? I have already tried upgrading to newer drivers, newer BIOS, newer much more powerful power supply
    Scholar:
  • 111 Answers
Hmm? Everything except replacing the motherboard, sometimes it does not get any better, but...go into your BIOS and turn off the Gateway splash screen. It will be an option in maybe the first or second menu choice. Make sure your on board video device is disabled and save your options when exiting. Good luck and let me know how it turns out.
Posted on Jul 03, 2009
Gateway computer is stuck in power saving mode.
The Gateway 818GM is a few years old but if - hopefully - the motherboard auto-detects a video card, try removing the MSI MS-8936 video card & swapping over the monitor lead to the other VGA connector fed from the motherboard.
Failing that, if you think it's a faulty video card, they're cheaply available on eBay eg for US$6.70 here:
MSI NVIDIA GeForce MX 4000 MS 8936 64 MB DDR SDRAM AGP 4x 8x Graphics
Feb 21, 2014 | Dell Dimension 3100 PC Desktop
What graphics card can i install in ms-6577 ver 4-1 motherboard
agp4x here manual to read http://www.manualslib.com/manual/650165/Msi-Ms-6577.html?page=30#manual
Jan 23, 2013 | MSI Ms-6577 P4 Motherboard Hp 5187-5628...
Can MSI MS-6380E support radeon x1800?
http://www.legendmicro.com/store/2940_MSI-MS-6380E-010-KT3-Ultra-Socket-A-Socket-462-for-AMD-Athlon-XPDuron-Processor.lmsp
1) Motherboard uses a Socket A processor socket. Also known as Socket 462.
http://en.wikipedia.org/wiki/Socket_A
When they switched from the Athlon single-core processors, to the Athlon 64-bit dual-core processors, they went to a completely different processor socket.
AM2,
http://en.wikipedia.org/wiki/Socket_AM2
So using the MSI MS-6380E motherboard with a dual core AMD processor = NO.
I don't seem to find an AMD Athlon 64 X2 1.8GigaHertz processor, except for a mobile version. One used for a laptop in otherwords,
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113047
Uses a Socket S1 mobile processor socket,
http://en.wikipedia.org/wiki/Socket_S1
List of AMD Athlon 64 microprocessors,
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors
Pretend like I'm from Missouri, and Show Me.
Find the processor by it's AMD part number, and post the URL of the website in a Comment.
http://www.amazon.com/AMD-Athlon-Venice-Single-Core-Processor/dp/B003RXLMCC
AMD Athlon 64 3000+
SINGLE-core processor, not X2.
(Socket 939 processor socket, too)
Show me the Processor, and then we can go on.
Regards,
joecoolvette
Sep 11, 2012 | MSI Computers & Internet
Radeon 9250 card is not work by system after system restore
Try unistalling the Dell Dimension Intel (R) graphics controller form your device manager...how?...
1. On My Computer, right click and select properties.
2. Select Hardware tab, and click Device Manager.
3. On the list of device manager, click View menu and select Devices bt type
4. Double click Display Adapters, to display the list of connected graphics adapter.
5. Disable the graphics adapter listed, by right clicking of the file name and select uninstall.
6. Now close any program and shutdown your computer..
7 Connect your video card to the motherboard and turn on your computer. Yous computer will run its add new hardware device , just be ready with your driver files..
I hope that will make your video card work again with your motherboard
Much appreciated if you rate this solution..thanks.
May 26, 2010 | ATI RADEON® 9250, (128 MB) AGP Graphic...
Ms 6787 no signal input
since you said you do not know anything anything about the jumpers and stuff, probably i suggest you take it to a nearest computer specialist to do it right for you. one thing you have to check up when installing a new motherboard is you power supply, does it have more or less power output? is the local disc or hard drive connected correctly? if you have no idea on all of this then there is a need to have a specialist to do it right for you becauase if not, there would be nothing for you computer to display.
looking forward to hear from you.
thanks,
wonder
Sep 22, 2009 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
Need of motherboard driver ms-7142
Your board is actaully listed as a model K8mm-V on the MSI website. Here is a link to the MSI page with the correct drivers for your board. These will work for Version 1 or 2 boards:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Hope this helps...
Sep 19, 2009 | MSI K8MM-V Motherboard
Connector diagram to acer ms 6772 motherboard needed
most motherboards have labels wherein you should connect the power button. facing the motherboard, try looking for it on the lower right.
Sep 16, 2009 | Acer Veriton 3600GT PC Desktop
Radeon graphics card and 3rd RAM slot conflict
I thought this board looked familiar to me. I recall some rules for the memory cards. Do all your memory cards meet this requirement:
Supports up to 3GB PC1600/2100/2700/3200* DDR SDRAMs
If you are using DDR 400 you can only use 1 slot.
What kind of memory are you using?
Jul 05, 2008 | MSI KT4V (MS-6712) Motherboard
Will ati card work in one monitor
Be sure that you have gone into your Bios on your computer and disable the onboard intel card that your using.
Aug 27, 2007 | ATI RADEON 9250, (256 MB) PCI Graphic...
Computers & Internet Logo
366 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
