Question about Advent Computers & Internet
Laptop wont switch on. power light not on nether when charger plugged in,charger light is on ,on charger
  • Advent Master
  • 32,281 Answers
A commom power problem with laptops. To determine if it is the power socket on the laptop is the problem, plug in the adapter into the laptop and wriggle the plug and look at the charge/power LED on the laptop. If the LED flashes as you wriggle the plug then :-
The problem is the power socket on the laptop, it may caused by a dry solder joint and needs to be resoldered or the power socket may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars.
If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
If these tests did not resolve your problem, then you could have a motherboard problem. A replacement motherboard may not be a cost effective solution. It may be better to put your money towards a new laptop.
Posted on Jul 02, 2009
Orange light trying charge
I would try this:
take the battery out
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
My advent laptop wont power up
The only way to check the charger which it looks like is
a) When you plug in the charger to the laptop are there any lights that come on anywhere on the laptop ( if so its not the charger )
b) Plug in an external monitor to rule out the screen ?
Apr 19, 2012 | Computers & Internet
My TV "Dynex DX-LCD37" shut
Since the TV is new I would suggest that you must not attempt to tamper the TV and give up the warranty on the set. So the best is to have an external check, remove the power supply and let the voltage drain off in the set and control panel, depress the control panel /start /standby switch/prog. switches.
If the set after this reset still prefers to shut down after a time period then there is a hardware issue on the processor section and it can be relative to hanging of the system.
I would request that you file for warranty free service immediately.
Sep 16, 2011 | Dynex DX-LCD37 TV
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
Laptop wont start at all. plug in to power supply and battery charging light comes on.still wont start up...
try diconnecting the charger and holding down the power up button for longer, then try plugging in charger- turn on charger at wall then hold down power on button till power button on key lights up, i hope this helps you out ;)
Feb 07, 2011 | Computers & Internet
Charger is plugged in but when i switch on, orange light flashes then stops but laptop wont come on
the issue might be with the charger which is not supplying power or is with the charger port in the laptop itself,it might be loose or it might be completely broken...try with different working charger which is working for another same kind o laptop if you can if it turns on the laptop replace or repair the charger..if the other charger also don't work it should be the port take it to the hp store to get it repaired...
hope it works
Oct 02, 2010 | HP Compaq 6720s Notebook
My laptop wont switch from battery power to wall plug power
because your charger is no good. It wont switch over to wall charger if if doesnt feel any power coming from the chrger.
Mar 13, 2010 | Computers & Internet
The laptop wont charge
Just because the light comes on does not mean the charger is charging. You will have to use a meter and check the actual output of the charger. The problem could be the charger , charger plug, cables or battery. Start the checks with the plugs and cables and go from there. The light can come on but no power going out to the battery.
Oct 12, 2009 | Toshiba Satellite A55-S1063 Notebook
Battery charging issue
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 11, 2009 | Advent Netbook
Computers & Internet Logo
160 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
