Question about Dishwashers
Water will not drain out at all left will a big
It is the frigidaire ultraquiet 3. water will not drain out at all left will a big Puddle of water in the bottom
  • 90 Answers
Often times the drain hose improperly installed .the hose needs to have aloop in it where it comes up above sink drain. if this is wrong ,take hose loose and clean out alsoconnection at disposal.
Posted on Jul 03, 2009
Frigidaire ultraquiet III dishwasher not draining
Will the drain hose drain into a bucket? If so the garbage disposer is probably plugged.
Feb 07, 2015 | Frigidaire Dishwashers
Leaking intake valve on frigidaire ultraquiet III, model: FDB750RCC1
Hello Dan Wetmore - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, keep in mind that the springs or hinges may possibly be damaged, gasket not sealing properly or the leak could possibly be coming from the drain motor/pump (which would be more cost effective to repair). I would strongly suggest contacting a professional to move forward accurately.
Dec 13, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Puddle of water in bottom of refrigerator
the drain in bottom back of freezer is pluged rsome hot water through it . ( use a turkey baster ) .. this should correct problem .. mm
Jul 04, 2010 | Frigidaire FRT21G3CW Top Freezer...
Water puddle on floor from inside refrigerator could it be defrost heateris bad? water accumulates in the bottom of freezer and freezes seems to come out of evaporator/fan location
unkink the drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water is leaking out of the front and back of frigidaire side fre
Clear the bottom of the freezor so you can get at the drain. then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the refrigerator side as well.
Good Luck,
Gilsh
Nov 29, 2009 | Car Audio & Video
My Fridgidaire Professional series refrigerator has a puddle of water in front of it about once every other day. The puddle is around the front on the freezer side of the fridge. What can I do to fix this?
Drain line in the freezer section is clogged, needs cleaning. There is a small drain pan on the bottom of the rear wall in the freezer. It is covered with ice. Defrost or remove ice, and get to the drain hole. try flushing with hot water, if does not help - clean mechanically on both sides of the drain line - in the freezer and in the back of the fridge, where it comes to the drain pan near condenser/compressor.
Oct 16, 2009 | Frigidaire Professional 26 cu.ft....
Puddle/ice in freezer compartment of my side by side fridgedaire. have chipped out the ice twice and blow dried everything to get rid of any ice jams. ice puddle comes back in a few hours
Check and see if your box is level. Levelling of your box, may solve your problem?. In some cases, the box isn't level, and the water from the icemaker spills into the freezer. If you don't have an icemaker, the evaporator drain could be clogged? When the evaporator defrosts, the water has to drain into the very bottom and outside of the freezer into a drain pan. If the drain is clogged, the water will drain into the freezer. Good luck. I hope this helped?
Jul 07, 2009 | Frigidaire FRS26H5AS Side by Side...
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Dishwashers Logo
96 people viewed this question
Top Dishwashers Experts
