Question about Raypak Versa 130,000 Btu Above Ground Natural Gas Heater
Raypak Versa 55B SPA Heater - new replacement installed for worn out prior unit. Installed fine, but igniter will not fire.
    Top Expert:
  • Raypak Master
  • 8,514 Answers
Check wiring
Posted on May 25, 2016
  • 246 Answers
SOURCE: Raypak commercial water heater requires reset to fire burners occ
DON'T KNOW WHY YOU HAVE A RAY PAK ON THE CAR WASH SINCE SO FAR I KNOW IS DESIGN FOR POOL AND SPA ONLY,THE HEATER NEED CONSTANT WATER FLOW BUT HERE WE GO, CHECK YOU BURNER FOR FIRE MARKS, CHECK THE HEAT EXCHANGER FOR SUIT BUILD UP (GREEN STUF) IF EVERYTHING OK THAN THE CONTROL BOARD NEED TO BE REPLACE.
Posted on Oct 31, 2009
john224
  • 1378 Answers
SOURCE: My raypak versa spa heater was making a loud sound
Part one - The 'whoosh' or 'boom' at ignition. If those sounds describe your start up your jet(s) are clogged along the gas manifold. Follow the pipe out of the gas valve down to where the gas is shot into the heater. Those bronze ports have a small opening and spiders like to nest inside this area. Turn them out of the manifold and inspect them. You should find those closest to the ignitor are clogged causing the delay and then boom of ignition.
Part 2 - Have this happen enough and the roll out switch / fused link along the bottom of the heaters service panel will open up and disable the heater. It will look like a black rubber tube about 1/4 diameter by about 2 inches long -OR- a white ceramic block about the diameter of a quarter; either will have 2 wires to it and it will be 'close' to the manifold and jets you need to clean out. If you have a way to read resistance across this switch remove the wires from it and check it. If it is open it will need to be replaced.
Posted on Dec 16, 2009
  • 990 Answers
SOURCE: Back flare on Raypak pool heater
You will need to pull the burner tray out and clean and blow out the burners. Then you will need to pull the orfaces from the gas manifold and clean each one and blow out the gas line. Then with a mirror you will need to check the fire brick inside the burner box. Then you will need to replace anything that is damaged. Good luck.
Posted on May 15, 2010
Testimonial: "thanks for the insight. I assume that I will have to disconnect the gas line and then reconnect afterward. Appreciate your information."
  • 767 Answers
SOURCE: I have a Raypac digital
Hello my name is Heath it will be my pleasure to assist you. Find the rollout switch and on the back there is a small red button if you push the button in it will reset the switch. The rollout is usually located near the burner section of the heater.I will attach a picture of a rollout switch which shows the small red button.11c0d2e.jpg
Posted on Oct 25, 2010
Coastsider
  • 331 Answers
SOURCE: heater fires up and is hot but does not heat the
This unit must have adequate water flow and apparently needs to be checked for proper operation.
Consider the following:
The unit as manufactured is equipped with:
  • pressure switch - likely stuck in the on condition, or been has been bypassed
  • Thermostat - Needs to be checked to insure it is properly working and calibrated.
  • Hi-limit switches - need to be checked to insure they are working and not bypassed.
  • flame sensor - prevents flame from leaving the firebox and damaging control area. (if equipped)
  • Flow Governor - controls water flow through the heat exchanger to prevent over pressure.
If the pressure switch is working properly, a blockage after the heater, would create pressure, but not enough flow. Check for a closed valve or obstruction in the plumbing.
If the problem is a clogged filter, and the filter is located before the heater, then the pressure switch is NOT working correctly and needs to be replaced or adjusted to factory settings. Remove the filter cartridge and check for flow.
Bottom line is:
No flow and no pressure, - heater should not come on.
No flow, but pressure, heater would come on and overheat, tripping hi-limit.
Good flow, heater would come on and spa would heat.
Posted on Nov 28, 2010
How do I diagnose ignition problem for raypak versa 055b ?
if pressure switch has voltage both sides check safety circuit if ok check ignitor
May 04, 2014 | Raypak Versa Propane Pool Heater - 55,000...
Just purchased Raypak Vera model 130A. hooked everything up, turned on propane and it is spraying out of gas valve?
well did you soap test the gas line going in/out the gas valve before firing up the heater????? wich you should always do!!!
Jul 08, 2012 | Raypak Versa 130,000 Btu Above Ground...
Hello my Raypak Versa Heater sounds like its working just fine. I have it on high and it is definetely letting off heat, but my pool temp has only climbed 1/2 a degree in 4-5 hrs. I have a 25ft x 8ft...
When checking functionallity of this heater heres what we need to look at.
Your pool is 6660 gallons with a 55,000 btu pool heater.
Right off the bat I can tell you that this heater is meant for a spa or small pool only.
Depending on where you are located this heater will not even keep up with heating this water in cold temperatures. You should have a 100,000-150,000btu heater installed for this pool.
Since this is what is installed, here it goes.
Make sure there is adequate flow to the heater. All heaters have a recommended flow rate which is more more productive than one that is too fast or too slow. Ideal for this heater is 55-65 gallons per minute, so make sure that the pump is not clogged and flowing freely.
Also, if this is an old heater and hasnt been serviced in quite a while, then the heat exchanger is probably overdue for a cleaning. When the heat exchanger gets dirty, all that heat produced by the burners just gets vented instead of heating the water. a yearly service is highly recommended on these low efficiency heaters.
By the way, you have a 55,000 btu heater that was 81% efficient the day it was installed.
This means that the actually heating btu's is already down to 50000.
the efficiency of these units will go down 2% a year if serviced, and about 3-5% a year if not serviced.
Long story short, the heater is undersized, and probably also needs to be cleaned.
Nov 15, 2010 | Raypak Versa 55 Electronic Ignition...
Heater not coming on
if voltage to unit then check transformer if voltage see if voltage to gas valve when igniting also check pressure switch
May 22, 2010 | Raypak Versa 130,000 Btu Above Ground...
Oct 30, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Raypak Versa 130,000 Btu Above Ground Natural Gas Heater Logo
78 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
