Question about Creda 24 in. DWI34 Built-in Dishwasher
Creda ID160 has flashing light - Creda 24 in. DWI34 Built-in Dishwasher
2 Suggested Answers
  • 167 Answers
SOURCE: I have a Creda ID160 dishwasher.I topped up the salt but after that the dishwasher makes a noise like it's starting switches programmes and does nothing for as long as it's on. What is the problem?
Check filter take it out clean and replace it hope this helps
Posted on Jun 25, 2015
Have replaced door seal in creda w220wv and door light flashing, will not start
Must have disconnected the wires to the lock switch or damaged it it is situated near the door seal to the right were the door locks you can fixet from the top cover once taken off hope this helps you can also test it by inserting a screwdriver small dimention once inserted you shoul hear a clicking sound by pressing it start program and the light should go off if it does not then the result is damaged or you have accidentally disconnected the wires fro it.
Mar 06, 2016 | Creda Washing Machines
CREDA FLASH PROGRAMMER 2S, I can programme the current time and the comfort / reduced mode, however when i set the slide switch to 'auto' all that is shown is 2 moons. According to the manual
Reset digital timers before programming to eliminate trace testing memories and restore full functionality
Make sure you're in correct mode fro programming: Time setting mode, with selector moved to top next to clock symbol
Compare your timer manual with Hagar manufacturer's generic manual for the 2-channel: English on page 3.
http://waterheatertimer.org/pdf/Hagar-monotron-200-2-channel-manual.pdf
http://www.credaheating.co.uk/assets/kb/operating_instructions/0/Flash_2S_Programmer_Instructions_Issue_1.pdf
Contact Creda
www.creda.heating.co.uk
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 18, 2013 | Hardware & Accessories
Creda excel W120VW the door lock light keeps flashing and cycle stops. If I hold the start button for a few seconds it starts again but then stops after about 2 mins.
From what you descibe it COULD be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 15, 2011 | Creda W120VW Front Load Washer
Hotpoint aquarius WML540, HAS JUST STOPED WORKING ITS ONLY OVER 1 YEAR OLD,WILL START ANY WASH BUT JUST STOPS WHEN IT REACHES THE SPIN AND DRAIN AND ALL LIGHTS START TO FLASH VERY FAST CAN YOU HELP.
Could be the pump blocked or not working, check the pump for blockages or wiring faults. For Hotpoint, Creda and Indesit error codes that include flashing lights visit selfix-uk
Mar 20, 2010 | Washing Machines
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
All lights on front flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If all the LED’s are flashing then you had better call out an engineer with the right test equipment because only a few LED’s should be flashing at any one time to indicate which area the fault is in. Click on the link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Creda 1200 w220vw
Door lock light flashing is not normal, check to see if door is shut properly,another problem could be a track blown on control module, you would need to remove front console to check this.
Apr 17, 2008 | Creda W120VW Front Load Washer
Dishwashers Logo
230 people viewed this question
Top Creda Dishwashers Experts
myrlanthian
Paula Hamilton
Colin
Are you a Creda Dishwasher Expert? Answer questions, earn points and help others
