Question about Daewoo DV-K84N VCR
What component is a C5021F-R
Friends: I have a Daewoo DV-K84N VCR. The problem is there is no power supply. I found a 3-pin component, C5021F-R burnt. Please tell me what this component is and if there is any cross reference. Thank you.
4 Suggested Answers
crazy larry
  • 6 Answers
SOURCE: Bush TV Dead MODEL: 5693D
switch mode power supply? it has a in or primary side and out the secondary side of a switch mode transformer.
check the driver IC that runs Q102 it makes a oscillation that Q102 amplifies. now the secondary if has a short will blow the Q102 look for shorted rectifiers in the secondary and fuse resistors that are open, even go far downstream and check the HOT for short.
Posted on Feb 23, 2008
SOURCE: Loss of station memory on Daewoo VCR
It is a capacitor numbered C501 and it's 0.01uf 5.5v.
You have to remove the mechanical part to get to the board.
G.A. Sheffield
Posted on Mar 05, 2008
  • 975 Answers
Posted on Oct 23, 2009
  • 1188 Answers
SOURCE: I have a Daewoo standalone
For the manual, please click here. I will guide you from the chat Window.
And for the remote, please click here.
Posted on Jun 23, 2010
0 characters
1 Points
I bought a used Daewoo DVK47N VCR player which works fine but i can't get the menu to come up. It will record if I push the record button and it plays back just fine but I can't program it.
You say "used" it may be the person who sold it you gave you the wrong remote. I should look around on Google for the model number and the number on the remote, to see if the two match up. If you have the manual it will often list the remote number. If you don't, try the Daewoo website, sometimes they have free PDF's of manuals. You could also ask them if the remote matches your model.
Otherwise it could be a fault in the electronics section of the VCR.
Aug 19, 2010 | Daewoo DV-K47N VCR
When i insert a tape into Panasonic AG-DV2700 Mini dv Playerecorder. It closes normally and then it puts the tape back out staight away Thanks Maurice
Dear FixYa customer,
There can be several reasons for the tape spitting back out including, a defective tape, foreign object/lablel in the cassette compartment, unit in timer recording with tab knocked out on tape and then actual mechanical and electrical faults.
I will concentrate on the mechanical and electrical faults here, since you can verify the others.
Electrical, would include the Power supply, and Micro processor circuits.
A weakened power supply due to deterioration of the filter components will kick the tape out if the power supply voltage drops below a certain value. The filter components deteriorate with age and heat, and then put out less voltage.
There are critical timing circuits, and sensors that control the mechanism positioning and send signals to the Micro processor. The tape in sensor, mode switch, and LED are common faults here.
Mechanical faults include the Cassette Loading Assembly, Capstan, and Drum motor. A fault in the casseette housing assembly that won't allow it to load 100%, a Drum or Capstan motor that is sluggish or frozen will send a signal to he CPU to kick the tape back out.
The Power Supply is a common failure.
An experienced technician can verify the power supply voltages and replace the filter components for approximately $25.00 plus labor.
Thank you for using FixYa
May 13, 2010 | Panasonic AG-DV2700 Mini DV VCR
VCR Connection
Mar 03, 2010 | Daewoo DV-K84N VCR
Iam looking for an english owner manual for this vcr
Manual (PDF, English) can be downloaded from here.
Good Luck!
Jan 27, 2010 | Daewoo DV-K47N VCR
Unit will not power on.
One or more sections of the power supply are not coming on. This unit has both fuses and ICP's (integrated circuit protectors) in the power supply that may open up causing your symptom. You will need to check and/or replace any open fuses or ICP's. If they immediately open up again, you will need the manual to figure out what is loading the power supply, or what component in the power supply has failed.
Oct 04, 2008 | JVC BR-DV3000U DV/Mini DV VCR
No power
This likely indicates a dead power supply, or a blown fuse in the power supply, and if the fuse is blown, this usually indicates a serious problem with it. If you have a voltmeter and some tech savvy, you could check for proper voltages produced by the power supply circuit. A normal power supply will produce: +5 volts, +12 to 14 volts, & a -40 volts or so. The latter is to power the LCD display, if present. If these voltages are missing, or way off, then you have a defective component in the power supply circuitry. Incorrect voltage values are usually point to a defective electrolytic capacitor. Replacement caps. can be found at Digi-key Corp.-- their Panasonic FC series is what you will want. Or, Mouser Electronics has suitable. If there is no voltage at all, then you may have a blown switching transistor, and perhaps a few other small parts bad. Tech savvy is a requirement here, as these kind of failures are frequently caused by a problem elsewhere, and a repeat poof is almost certain unless the other problem is found & repaired. Otherwise, if this is a low dollar VCR like most of the last 10+ years, repairs might not be economical.
Jun 25, 2007 | JVC HR-J692U S-VHS VCR
My DV-T5DN won't turn on...
your vcr timing is out or mode switch isfaulty.disconect vcr from plug for 20 sec plug back the tape mechanism should reset
Dec 23, 2006 | Daewoo DV-T8DN VHS VCR
Daewoo DV-K84N VCR Logo
93 people viewed this question
Top Daewoo VCRs Experts
alexander woolfolk
alexander woolfolk
Are you a Daewoo VCR Expert? Answer questions, earn points and help others
