Question about Kenwood CD-403 5-Disc CD Changer
Why wont my kenwood cd player work ? It wont play open or do anything it wont let me do anything .
  • 2,071 Answers
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Posted on Jul 02, 2009
Kdc-mp
put a cd cleaner in your cd player see if that helps.
Feb 16, 2014 | Kenwood KDC-MP435U CD Player
Kenwood cd player - Since i used an ipod, it comes up error 5, and wont let me play a CD in the car, or any other Ipod. Any ideas on how to reboot the player, or get it working.
According to experts, error 5 on the player means that the player is reading the cd upside down or it cannot read the disc. you may need to run a cd cleaner ten check if it can read the cd again or if not you may need to take the player apart to clean it manually.
Cheers!!
Sep 03, 2010 | Kenwood Audio Players & Recorders
Why wont my cd play in my kenwood kdc 2022?... the cd goes to E-04 or something like that
Clean your player head using some buds or something for that you have to take out the system and open it and then clean it . Also check the quality of the CD ,sometimes the bad quality scratched CD wont get accepted. I think the first solution wil work for U
Thank U
Please rate me as it wil cost u just one click
Oct 23, 2009 | Kenwood KDC-2022 CD Player
I have a kenwood w313 car cd player and it wont store anything
Check you wiring. There are going to be 2 powers in the back of the radio. The yellow wire is the constan/memory wire. Make sure you have it hooked up to constant power.
Sep 03, 2009 | Car Audio & Video
Kenwood car am/fm cd player loads cd ok but spits it out
Try to purchase a CD disc cleaner, sometimes the "eye" gets partials of dirt on the lens. If that's the problem the cleaner will fix it in no time.
May 26, 2009 | Kenwood Car Audio & Video
Cant change the back ground on ddx-512
i have a kenwood car cd player. when i hook it up i puy in the security code 3275 but it still does not allow me to play cd or radio. what else do i need to do?
Feb 03, 2009 | Kenwood DDX-512 Car DVD Player
CD Player
TRY TO ORDER THE MANUAL IF U DONT ALREADY HAVE IT AND LOOK IT UP OR U CAN TRY THIS: FIND THE RESET BUTTON AND RESET IT. U MIGHT HAVE A CODE ON IT OR IT MIGHT BE SET ON DEMO
Sep 21, 2008 | Kenwood KDC-MP4028 CD Player
Kenwood kdc-x859 just stopped working
This hapened to me also. I removed the power fuse to the radio and it reset itself.
This solved the problem for me.
Feb 28, 2008 | Kenwood KDC-X859 CD Player
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
Kenwood CD-403 5-Disc CD Changer Logo
1,039 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
