Question about Jl Audio 250/1 Car Audio Amplifier
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
I just bought a JL audio 250/1 amp, to power my pioneer champion series TS-W307D4
rms ratings: the amp is rated at 250 W rms, the sub at 400 W rms
When the amp's settings are normal, i mean when its pumping exactly the 250 watts (22,4 volts at 2 ohms), the sub doesnt do much
should i go for a more powerful amp?
is it safe to set the gain on this amplifier really high to get almost 600 W rms? (35V*17,5 amps on the output level)
How much power can i get from that amp before its dangerous for it?
and is it suitable for my sub?
    Problem Solver:
  • 16 Answers
You should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Posted on Jul 03, 2009
What would be the best amp for the money to push 4 pioneer 6.5 i door spea kers n in my truck? they are pioneer ts-a1674r. 6.5 '..3-way 300W max and 35W nominal.
i would get me a 400 watt pioneer amp that ran the same ohms as my speakers maybe a 500 watt to much power on 6.5 will pop them dont ever goby max power its to much for them
Mar 04, 2013 | Jl Audio 13W7 Car Subwoofer
What amp to use for two pioneer ts-w307d4 car subwoofers
Just get 2pi amp pros at1200 watts. That way u have full control of the bass u need. Just remember to turn the amps down the subs are a little under rated. Done this myself and it is a great sous. There not a good pro sub but they will do the job in a mid size car
Jan 30, 2012 | Pioneer TS-W307D4 Car Subwoofer
I have a ts-w307d4 pioneer sub woofer and its a 4 ohm sub that has 4 terminals on it 2 red and 2 black how do i wire this sub to my amp i have a sony 1200 watts stereo amp and my sub is a dual voice coil...
conect one of the positive terminal from the sub directli to one chanel of the amp, and do the same with the negative,and do the same with the others terminals from the sub conect to the other chanel
Aug 12, 2010 | Pioneer TS-W307D4 Car Subwoofer
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
I have the pioneer sub and a sony 600watt 4
it has a detector that kicks in it will usually shut off your amp and it keeps you from blowing your amp the speaker may have to much power and amp may not push it it will start to protect itself
Jun 07, 2009 | Pioneer TS-W307D4 Car Subwoofer
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 250/1 Car Audio Amplifier Logo
379 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
