Question about Bosch HBN 455 Stainless Steel Electric Double Oven
Fan won't turn off & upper oven work in Manual mode
I have a used Bosch HBN456AUC convection oven that the fan just started running constantly. It has been installed in it's current position for about three months with no issues. I also found that the oven doesn't heat if the oven is set to Manual. The oven does heat however if you put it into Timed Mode and set the timer.
I have turned the circuit breaker off and then on and that doesn't clear it. Any ideas?
    Top Expert:
  • Bosch Master
  • 78,267 Answers
This sounds like a control panel issue, you may have to replace it, about $300.00
Posted on Jul 09, 2017
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
SOURCE: bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
Posted on Jan 18, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
taran_2005
  • 10515 Answers
SOURCE: I have a Bosch HBN 455 double oven with the
Do you see any Error Message on the Display?
If not, then it should not be a Concern. More often this could be Thermal Fuse on the Back of the Unit ( On Most Models ) will stop the Broil and Bake from Turning ON. You would just start a bake cycle and the temperature will sit at 100 and something degrees and never raise.appliance.
Let me know, once you check the same.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 28, 2009
I have a Bosch white single wall oven HBL54AUC. It is very loud and I don't know why. It works...just too loud. Any suggestions? Linda :
Good morning Linda, the noise you're hearing is probably the cooling fan with a bad bearing. That would be the only moving part that would make noise. It's a pain in the neck to get to but fairly easy to swap out. Definitely easier with two people. Or it could be a bad bearing on the convection fan motor. Set it to temp and then open the door once it starts to heat, That will cut power to convection fan and noise will stop.Hope that helps.
Feb 08, 2018 | Bosch Ovens
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
I have a bosch Oven model HBL745A UC and the heating element at the back of the oven won't turn off.
Most likely part is the oven control board, it has relays on it . There is one stuck. IT is 2235 dollars to replace.
Dec 09, 2013 | Bosch HBL 745 Stainless Steel Electric...
Oven fan not working
If you're referring to the fan in the rear for convection cooking (as opposed to the fan for cooling the electronics), it's replaceable by removing the oven rear panel (power off, of course). Bosch Part 490358
Jun 19, 2013 | Bosch HBL 445 Stainless Steel Electric...
FAN ASSISTED PART OF OVEN DOES NOT WORK - ALL OTHER PARTS OF OVEN WORK
3ce67db2-692b-4b64-9a3b-5ffc185dfc29.pngIf its convection , take the back panel off inside the oven an change the element . Ta daaaaaaaa !
Dec 26, 2009 | Bosch Ovens
Bosch convection double oven,ovens won't heat,only broilers work
Thanks.
Dec 17, 2008 | Bosch Ovens
thanks.
Nov 08, 2008 | Bosch HBL 745 Stainless Steel Electric...
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
May 28, 2008 | Ovens
Bosch HBN 455 Stainless Steel Electric Double Oven Logo
430 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
