Question about Lexmark X7350 All-In-One Printer
I have a Lemark X7350, I need to order a AC adapter. I have the power cord, but I need the adapter. Where can I order one from? Ronnie
    Scholar:
  • 111 Answers
I need a cord for my lexmark fax/printer/and copyier machine
Search for Clover leal C5 power cable / lead / cord
Plenty around especially on ebay.
Serch for 32FB adapter if you want the actual power unit.
Oct 01, 2014 | Lexmark X7350 All-In-One Printer
Tip
Troubleshooting Laptop Power Failures - The AC Adapter
Symptom:
Wiggling the AC adapter cord causes the power status LED on the laptop to blink.
Diagnosis & Solution:
The problem could be that the copper wires inside the AC adapter cord became frayed or broken right where they enter the connector on the end of the AC adapter cord. The wires (a number of very thin conductors twisted into a heavier cable) are sized for the amount of power the laptop requires. As thin wires break and lose contact, all of the power must flow through the remaining conductors, leading to overheating, which can cause damage or be a safety hazard.
To make sure that this is the case, first test the output voltage from the connector on the end of the AC adapter cord using a digital multimeter set to measure DC voltage. While measuring, bend the AC adapter cord in various directions. If this causes the reading to jump betwwen zero & the nominal output voltage (written on the label on the AC adapter), then you know that you will need to replace the connector.
In order to get this fixed, you will need a new connector and basic soldering skills, or you can take it to an electronics shop for a cheap repair but get the price before agreeing. If you decide to repair it yourself, then you will have to find a replacement connector. Most of these connectors are easy to find and your local Radio Shack often has them in stock. Just bring your laptop along to make sure you get the right size. However, some laptops use a highly proprietary connector for which you can't easily find a replacement, in which case your best option is to find a failed AC adapter for your laptop model, cut the end off (with plenty of slack) and splice it onto your AC adapter's cable.
If you work on irregular surfaces (like a lap) and allow the cord to dangle, the wires may break just inside the connector due to pulling, despite the fact that the factory connector is encapsulated in molded plastic. You can carefully take apart the molded plastic with a razor knife to temporarily fix a connection, but it's smarter to replace the connector end as soon as you determine it is causing intermittent power failures.
Another possibility might be that the power receptacle in the laptop (where you plug the AC adapter cord) has failed. Sometimes the center pin of the connector breaks off, sometimes the solder joints on the main board fail, sometimes there's a break between the connector contacts and the motherboard contacts. In all these instances, you or the technician has to gain clear access to the laptop's motherboard to make the repair. In order to get this done, you might need clear disassembly instructions, as well as decent soldering skills. You could get a replacement connector usually for less than $10, but the repair charge can be several hundred dollars for some models if you take it to a local shop.
Please Vote for this Tip if you found it helpful.
M. Omran
on Oct 13, 2010 | Computers & Internet
I need to order USB cord/AC/charger cord I have the I7 with 8 g memory my computer serial# A4N0AS3428021G
PLease go to eBay and type in the Model# (not the serial) in their search box followed by "AC Adapter Charger" and you will have choices.
Regards,
The Selkie
Sep 28, 2010 | ASUS AC Adapter- Universal Notebook AC...
The WII does not turn on, what do I check to fix it?
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Hope that helps!
Aug 12, 2009 | Nintendo Wii Console
When lighting hit and the wii go out what do i do to make it come on
Try the following steps in this order:
FIRST:
SECOND:
THIRD:
FOURTH:
MUST DO:
- buy a good SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 01, 2009 | Nintendo Wii Console
Samsung ltm1755b dc cord missing/need replacement
You can order a replacement AC/DC adapter power cord for this model (LTM1755B) from a major Samsung parts distributor at the link below:
Samsung LTM1755B Replacement Part AC/DC Adapter Power Cord
Apr 17, 2009 | Samsung LTM1755 17 in. HD-Ready LCD...
I need to order a whole set of new cables
copy and paste the following link - this item is on ebay:
http://cgi.ebay.com/9V-AC-power-adapter-for-Durabrand-PDV-705-PDV-709-DVD_W0QQitemZ260123773606QQihZ016QQcategoryZ15055QQrdZ1QQssPageNameZWD1VQQtrksidZp1638.m118.l1247QQcmdZViewItem
Jan 11, 2008 | Durabrand PDV-705 Portable DVD Player
LOST POWER CORD
I need a new ac adapter and I sent an email to evergo@att.net which is the customer service for the company that makes the PDV-709 dvd player. They responded within 1 day and gave me the instructions as to how to order one from them and the price ($20) etc. They require a money order sent to the address below.
Lenoxx Customer Service
Lenoxx Electronics
35 Brunswick Ave
Edison, NJ 08817
Oct 11, 2007 | Durabrand PDV-709
AC Adapter Light Going on and off
This happened to me as well. I did some research online and found that it is a common complaint for the AC adapters that come with these laptops. Basically, the wiring is very fragile, and the adapters only tend to last a year or two. Unfortunately, you will probably need to buy a new adapter.
Sep 26, 2007 | Dell Inspiron 9200 Notebook
Lexmark X7350 All-In-One Printer Logo
83 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
