Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
My stainless steel Mr. Coffee maker just quit perking coffee and the water does not run totally through. It has been perking slower and less quantity but today I cleaned it by running vinegar through it and it did not perk but a few seconds.
    Problem Solver:
  • 14 Answers
This is set up on a conventional mr coffee; if the hot plate is not as hot, it will not work, on the newer ones, a small chip could be getting hot, and like a car, it will either shut down or work part time. send it back to mr coffee, and they'll repair it, but it might be cheaper to replace it.
Posted on Aug 25, 2009
Saltonusa com
SORRY but this is not the correct website for any coffee maker we sell nothing !!
Dec 09, 2017 | Farberware Stainless Steel 12-Cup...
My new percolator will not perk? Water gets hot but doesnt seem to rise to the top.
I had the same problem, and I figured it out. Read on, to see if this applies to you. This percolator was received as a present years ago, and I'm not sure it ever worked right. First, some info and background. The above comments about the heating element being clean to bare metal, while valid, did not work for me. I also read other posts suggesting the thermostat might be defective, which also did not seem to apply to my situation because the water is always hot enough at the end of the cycle, not boiling, but steaming hot enough for just about anyone. I deduced the problem to be with the actual perking process, not heat or heating element. A percolator should perk before the water is at drinking (HOT) temperature, and the perking action cools the water and prolongs the actual perking process. The problem I found was with the washer at the bottom of the tube, which is supposed to act like a 1-way valve. The washer, from the factory, was apparently too loose with almost a 1/4-inch or play, allowing hot water that would otherwise perk back into the water chamber, effectively making my percolator into a kettle. I used a stainless steel washer and an e-clip to tighten the washer against the holes on the lower umbrella-shaped flange so that there is just enough room to slide a feeler gauge or perhaps a couple of sheets of paper. Now the percolator works great, fantastic actually. Watching the coffee perk at the top in anticipation of a hot cup is entertaining, and with the stainless steel pot I have no worries about phytoestrogens leaching from plastics common in drip coffeemakers. See photo of my hack if it uploaded correctly. Its high res, so you may be able to download and zoom in. Enjoy! new-percolator-will-not-n1see0xg4iab1sfdaqlesvfh-4-1.jpg
Oct 18, 2010 | VillaWare Mini-Perk 5120-05 Coffee Maker
Maker clicks on, but doesn't perk or heat the plate.
Unlike older coffee makers, the new Mr. Coffee designs seem to have reliability issues in regard to their circuit boards/controllers. You are right in your thoughts. If the unit is under warranty, I would suggest returning it for a replacement. E-mail your concerns directly to the company.
BTW--there are no user serviceable items within your coffee maker.
Mar 26, 2009 | Mr. Coffee FTX49 12-Cup Coffee Maker
Hamilton Beach 40616 Perculator
Try to replace the delivery (ascending) pipe in the middle.
Hope this can help you
Mar 24, 2008 | Hamilton Beach 40616 Coffee Maker
42115
This often happens when there is too much coffee put in to start with. The coffee grounds expand when wet so take up more room. If it is too full to start with then the water has to build up too much pressure and that raises the boiling point. When the espresso is finished the coffee grounds should not be packed solid. You should be able to poke a hole in it with your finger.
Jan 26, 2008 | Bialetti Venus 4 cup stainless steel...
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
618 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
