Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Brother 1840c -problems after changing cartridges
Just changed all cartridges as said ink empty. Brother cartridges used and machine still saying ink empty- why?
  • 1,959 Answers
If you are using new cartridges, the problem is in the sensors. The ink sensors get dirty and malfunction. Remove the ink cartridges and thoroughly clean all the surfaces, Allow to completely dry and replace the cartridges. This should cure your problem.
p.s. I usually use alcohol on a Q-Tip to clean
Posted on Jul 03, 2009
I have a brother intellifax 1840c (which is great, by the way). I need to change the ink cartridge & have no idea how to get into it. Is there a latch or button to help open it? Please help.
1 Close the document support and the document tray.
2 Lift the top cover to the open position until it locks securely into
place. If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Open Cover.
3 Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
You can find the procedure on changing the ink cartridges in the user manual, page 12-25.
User Manual can be downloaded:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000335/MFC-3240C_UsaEngUsr_C.pdf
May 25, 2011 | Brother IntelliFAX 1840C Plain Paper...
How To Change Ink Cartridge in Brother intellifax Model 1840c
I have this book to this printer, but the printer is tour-up. all you have to do is open the cover, and to your right will be 4 cartridges, release the latch on them, remove by pulling up on them, then replace them, the same way you took them out. Hope this helps
Oct 20, 2009 | Brother IntelliFAX 1840C Plain Paper...
I have a Brother 1840C fax machine. I have lost the manual. I need to change the ink cartridges and do not know how to do this. I need a graphic and instructions.Thank you
Just open the top cover of the printer, there will be 4 cartridges on the right side. they are locked in, all you have to do is release the little latch and pull out the cartridge, then replace it. I have the book, to that printer, but my printer is tour-up. Had to buy another one. Hope this help.
Oct 08, 2009 | Brother IntelliFAX 1840C Plain Paper...
No cartridge
A “No Cartridge” error message on 1960c products is caused by third-party (non-Brother) ink cartridges
leaking ink onto the Ink Sensor PCB and shorting out the cartridge sensor. In order to resolve this issue, a new
Ink Sensor PCB will need to be installed.
Jun 11, 2009 | Brother IntelliFAX 1840C Plain Paper...
Brother IntelliFAX 1840C says to change yell even though its full
Your machine did not recognize the new cartridge. Remove the yellow, count to 10 then replace it. The machine will ask "did you change the color yellow?" Select yes by dialing "1" - if after the cleaning cycle "near empty" still appears, you need to contact Brother for repairs. You can safely use the machine until "INK EMPTY" appears.
Mar 30, 2009 | Brother IntelliFAX 1840C Plain Paper...
Ink cartridge was changed, but machine won't work
There are lots of NEW dried up ink cartridges out there.
Nov 10, 2008 | Brother IntelliFAX 1840C Plain Paper...
Printing
other inks may be clogged, take out and put cartridges on paper towel, does it drain on the towel? if yes check the printhead.
Nov 14, 2007 | Brother IntelliFAX 1840C Plain Paper...
Brother Intellifax 1840C
Brother Intellifax 1840C the only one thing you can to do is stick masking tape around the cartridge, there is an switch, when you take off the cartidge the switch is off, when you put it on the switch is on, this is out = "off" and in= "on", do the same with the other colors.
greetings.
May 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
237 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
